95 GSR CEL 41 (O2 Sensor) Help
Old Aug 16, 2008 | 09:04 PM
GSRalive's Avatar
Default 95 GSR CEL 41 (O2 Sensor) Help
My car is throwing CEL code 41 which is the O2 sensor, so I put new O2 sensor in. I recent the ECU and started the car, but the check engine light came back on. I can tell my car is running rich from the unburnt gas that you can smell coming out of the exhaust. What else can I do. Should I check and see if my ECU is getting a signal from my O2 sensor, or see if my O2 sensor is getting power? Or should I do something different? And how do I check If my ECU is getting a signal from my O2 sensor? Any input would be nice... and it would be nice getting a little better gas mileage.
Old Aug 17, 2008 | 11:37 AM
Left_Sock's Avatar
Default Re: 95 GSR CEL 41 (O2 Sensor) Help (GSRalive)
I have the exact same code and the same problem! Im thinking it might be the O2 Sensor heater wire??
Old Aug 17, 2008 | 07:35 PM
GSRalive's Avatar
Default Re: 95 GSR CEL 41 (Left_Sock)
The heater wire? Is that the wire that goes from the O2 sensor to the ECU?
project91crxsi
41
Oct 30, 2009 04:56 PM
JoshJosephKeith
May 4, 2009 04:38 PM
anothersickhatch
May 15, 2004 10:22 PM
92CiviCJdMMX
Feb 4, 2004 11:38 PM
DreamSpeed
Jan 13, 2002 11:29 PM
