Suspension & Brakes Theory, alignment, spring rates....
Optimum camber/toe settings DD street sol
Old Aug 16, 2008 | 04:10 PM
Sold Out's Avatar
Default Optimum camber/toe settings DD street sol
Im about to install my F/R Ingalls camber correction kit and was wondering what would be optimum for the street?
Car will prolly never be tracked but maybe a autox or 2.
For now it has Tokico red/blues up front and stock del sol vtec suspension in the rear.
No strut tower bars.
15/50/205 azenis615 all around.
Remember sol is daily driven so I want performance and tire life.
So Im looking for camber and toe settings please.
Sold Out
Old Aug 16, 2008 | 08:06 PM
japanjay's Avatar
* B A N N E D *
Default Re: Optimum camber/toe settings DD street sol (Sold Out)
I have a DA and I am running 215/45r16 RT-615's with -2*f/-2.5*r on my DD for the last year with no problems. Havent even rotated my tires and they still look almost brand new.
Old Aug 17, 2008 | 08:55 AM
02 accord's Avatar
Not sure about the optimum camber, but set your toe to 0 all the way around to keep the tire wear to a minimum.
Old Aug 17, 2008 | 10:07 AM
TNguyen's Avatar
On my ep3 I had -2.5 front and -1.0 rear with 0 toe. Handled pretty good.
Old Aug 17, 2008 | 01:50 PM
sirlaughsalot's Avatar
Keep toe at OEM specs...I put my teg at 0 toe in the rear when it should have been .10, and the car handled like ****.
Some toe might be needed on our cars, thats why factory put it there.
Old Aug 17, 2008 | 03:03 PM
Sold Out's Avatar
so what would factory toe setting be for my 95 del sol vtec
Old Aug 18, 2008 | 09:27 AM
Sold Out's Avatar
bump for more of your dd settings
Old Aug 18, 2008 | 02:42 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Sold Out)
I always align my cars to stock toe specs for best tire longevity(drive R comps daily )
Camber is usually about 2.5 fr, 1.5 rear
Old Aug 18, 2008 | 03:00 PM
TunerN00b's Avatar
Default Re: (sirlaughsalot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirlaughsalot &raquo;</TD></TR><TR><TD CLASS="quote">Keep toe at OEM specs...I put my teg at 0 toe in the rear when it should have been .10, and the car handled like ****.
The factory spec for rear toe is to trade some tire lifespan (and mileage, since any toe is scrubbing tire) for high speed and braking stability.
I much prefer how much better my Integra rotates without the stock rear toe. However, I run it with the stock rear toe since its my daily.
Novice driver should keep the stock rear toe settings. Knowledgeable drivers should know enough to decide which trade off they prefer for their situation.
Old Aug 18, 2008 | 03:11 PM
Sold Out's Avatar
ok so factory rear would be 0 toe
what would be high speed and braking be for dd R toe setting?
Old Aug 18, 2008 | 05:22 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sold Out &raquo;</TD></TR><TR><TD CLASS="quote">ok so factory rear would be 0 toe
what would be high speed and braking be for dd R toe setting?</TD></TR></TABLE>
Um, is that English?
Stock rear toe spec (on most any FWD car) is a slight amount of toe in. Heck, even my 1983 Chevy Cavalier, which had a solid dead axle in the back, had slight rear toe in.
0 rear toe is acceptable for street use, just know what you are doing to your car. It will not be as stable as stock under all conditions.
Rear toe out is awful on the street (both to drive and for your tires), but great for autocross (in some cars).
Old Aug 19, 2008 | 06:56 AM
Sold Out's Avatar
ok so 0 toe on all 4 and 2.5fr and 1.5 rear negitive will be my settings along with a full alignment. thanks guys
Old Aug 19, 2008 | 01:09 PM
Targa250R's Avatar
be professional
I'd run 1/16" total toe-in at the rear to keep things in check. Toe-out in the rear of a del Sol is extremely sketchy under braking, and I'm a bit leery of zero toe on that car as well.
You can't adjust camber without threaded spring perches or camber adjuster kits, so forget that for now.
Old Aug 19, 2008 | 05:03 PM
Sold Out's Avatar
Yeah but I will do all adjustments at once alignment, camber, toe so I want to know all specs so I can tell the shop and they can just do thier thing.
Targa you sound like you know your stuff about sols so I want to run 1/16th of a degree toe in on the rear.
As for the front 0 toe? or no?
Camber fr ? and rr?
Old Aug 20, 2008 | 08:25 AM
Targa250R's Avatar
be professional
I'd run 0 toe up front.
Like I said, camber is not adjustable on your car unless you have a camber adjuster kit or can adjust the ride height via threaded spring perches. Only toe is adjustable from the factory.
Old Aug 20, 2008 | 04:24 PM
Sold Out's Avatar
Targa I know camber is not adjustable in stock form thats why I have a brand new F/R Ingalls camber correction kit about to go on.
I just want all specs ready to give to the shop.
Old Aug 20, 2008 | 07:08 PM
Targa250R's Avatar
be professional
I have no idea how I missed that in the original post.
Old Aug 21, 2008 | 05:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Why bother with camber kits if you have stock rear suspension?
I personally wouldn't bother with them at all with your setup. Have them set the toe and that's it. Make sure the rear thrust angle is as close to 0.00 as they can get it.
Old Aug 21, 2008 | 02:19 PM
Sold Out's Avatar
B/c I like the idea of improving handling plus I will be upgrading my suspension soon
Old Aug 30, 2008 | 07:56 AM
c5R's Avatar
c5R
when every one says a 1/16th is that total or perside ive allways wondered this
marcelosm
Nov 24, 2014 07:58 AM
tojo909
13
Jul 13, 2010 05:09 PM
sykotik sol
Nov 26, 2008 10:03 AM
Francesco
Honda S2000
32
Jan 30, 2006 08:33 PM
Lewie
Feb 17, 2003 10:46 AM
