Need some help on golden eagle head studs torque specs
Old Aug 16, 2008 | 04:00 PM
HondaCamp's Avatar
Default Need some help on golden eagle head studs torque specs
not sure if this is the right place,I got a b18b going to put a b16 head on it I need to know the torque spec
please that's the only thing stopping me from finishing my build I know that b20/b18c
are the same please someone help
Old Aug 16, 2008 | 04:04 PM
rev-speed's Avatar
60 to 70 ft lbs wil be fine
i would run 60 for almotor and 70 turbo
Old Aug 16, 2008 | 04:24 PM
non-VTEC's Avatar
Default Re: Need some help on golden eagle head studs torque specs (HondaCamp)
i just got finished installing GE headstuds a few hours ago.
the instructions say to torque the studs into the block to 10ft/lbs.
then with the supplied lube on the threads/washers/nuts you torque them down to:
25ft/lbs first pass
50ft/lbs second pass
then the instructions tell you to loosen and retorque each nut back 50ft/lbs 3 times to properly stretch/seat the threads. do one nut at a time. do not loosen them all at the same time.
then the final torque spec is 72ft/lbs
hope that helps.
Old Aug 16, 2008 | 04:35 PM
HondaCamp's Avatar
Default Re: Need some help on golden eagle head studs torque specs (non-VTEC)
thanks<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i just got finished installing GE headstuds a few hours ago.
25ft/lbs first pass
hope that helps.
</TD></TR></TABLE> thanks man u made my day bro
Old Aug 17, 2008 | 03:10 AM
stumpyf4's Avatar
These numbers are with the Torco assembly included with the studs.
Old Apr 20, 2015 | 05:18 AM
Snailor Built's Avatar
What are the specs for torquing used GE's?
Old Apr 20, 2015 | 07:09 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If I was to hazard a guess, the exact same way as stated above with the new studs.
The challenge will be with finding their custom lube. I would contact GE to see if you can get their lube.
avotegra
Dec 27, 2015 01:26 PM
HondaCamp
Aug 19, 2008 04:46 PM
BfromSD
Sep 3, 2006 08:24 AM
BrightRedOne
Oct 24, 2004 09:45 AM
itralex
Oct 17, 2004 08:29 AM
