dim e brake light on all the time
Old Aug 16, 2008 | 03:15 PM
1kleenef's Avatar
Default dim e brake light on all the time
i recently noticed that my brake light in my dash cluster is on all the time but it is dim and when i apply the ebrake fully it is 100% bright i have checked the switch that is on the ebrake handle is good i checked the brake master cylinder switch it is also good. I jacked the car up and the rear wheels spin freely. I am out of ideas to fix this please help.
Old Aug 16, 2008 | 07:31 PM
1kleenef's Avatar
Default Re: dim e brake light on all the time (1kleenef)
ne help
today it just started to come and go it will dim and brighten by itself anyone have any advice
Old Aug 16, 2008 | 07:41 PM
Brain909's Avatar
Have you checked for any bad grounds anywere?
Old Aug 16, 2008 | 07:43 PM
1kleenef's Avatar
Default Re: (Brain909)
no i need somewhere to start does anyone know where to start checking or a list of grounds and there specific locations thanks
Old Aug 16, 2008 | 07:47 PM
acmoc's Avatar
Default Re: (1kleenef)
maybe adjust your e-brake an check your fuses and bulbs
Old Aug 16, 2008 | 07:56 PM
1kleenef's Avatar
Default Re: (acmoc)
i have already checked the adjustment and the fuses are good i would just like some advice on where to start checking grounds
Old Aug 17, 2008 | 06:00 AM
beige89civic's Avatar
* B A N N E D *
If you unplug the E-brake switch and the master cylinder low fluid switch does it go away?
Old Aug 17, 2008 | 01:01 PM
1kleenef's Avatar
Default Re: (beige89civic)
no it is still on when i disconnect both just dimly though
Old Aug 18, 2008 | 10:35 AM
Hondaisok's Avatar
I agree w/previously mentioned bad ground. Mine did this before, it was the ground from the frame by the radiator to the valve cover. Be sure to put a heavy duty wire on there. Also check other grounds and clean contacts. I put an extra ground or two on mine just to be sure.
Old Aug 18, 2008 | 03:03 PM
Tyson's Avatar
another area to check is the back of the gauge cluster and clean the contacts of the wire harness connector and guage. take the bulb out too and clean it.
Old Aug 21, 2008 | 07:59 PM
acmoc's Avatar
Default Re: dim e brake light on all the time (Tyson)
brake fluid might be bad
Old Aug 23, 2008 | 07:09 AM
1kleenef's Avatar
Default Re: dim e brake light on all the time (acmoc)
no brake fluid is good still looking for a solution
Old Aug 24, 2008 | 06:30 AM
* B A N N E D *
I'd check for a blown fuse. My 91 Full size Blazer did this exact same thing and it was a blown fuse. Use a good test light and check EVERY fuse under the hood and under the driver knee blocker.
Old Dec 28, 2008 | 08:25 AM
txihondatec's Avatar
ttt on locations on the grounds please link anything
Old Dec 28, 2008 | 08:37 AM
Je2RiT's Avatar
theres a ground under the dash (ground wire in dash wire harness).. if you sit in your seat.. on the right of the steering column theres a ground there... (screwed upward)
are there any other lights next to it that are on all the time? if so there may be a crack that lets light go through...
Old Feb 1, 2009 | 01:15 AM
yuletak's Avatar
I just had this problem. Checked the circuits from the brake fluid reservoir and the e-brake. Light stays on regardless of those circuits. Then I took out the instrument panel cluster first before moving on to the Integrated Control Unit circuit. Didn't find anything in the IPC, but when I put everything back together, the light went away and hasn't come back yet. Very weird. Looking at the circuit in the back of the IPC, seems like the grounds go straight to the chassis via screws that hold everything together. I can only take a guess that some part of the circuit was being grounded that shouldn't have. Hope this helps someone else. I'll report back if my light comes back on.
Z20rider
Honda Civic (2001 - 2005)
Nov 30, 2015 07:21 AM
PJXKEM
Sep 4, 2012 10:32 AM
riznup23
May 3, 2010 05:55 AM
BigAnteg
19
May 21, 2009 05:44 AM
