Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
sub install
Old Aug 16, 2008 | 02:02 PM
phoshizzle88's Avatar
Default sub install
ive installed systems before. but not on a stock deck. i have an 07 accord. i wanna put my subs in but keep my stock deck for the steering wheel controls and cd changer. is there a write up on how to do it>
Old Aug 16, 2008 | 08:22 PM
Ross 2.0's Avatar
In a Junkyard near you.
I can't help you. Just be SURE you know what you are doing. That audio unit costs well over $1,000 to replace and it is very sensitive to abnormal voltages. If you do it, make sure you do it right.
Old Aug 19, 2008 | 09:57 AM
Ho!cord!V6spd's Avatar
would a high voltage input equipped amp, a wire or two run from the rear speakers to the high voltage input on the amp, and your subs work?
I have seen a friends car done like this, but I can't say I have ever done it myself.
I would be worried about the stock headunit, since I just found out it cost over 1000 to replace!!!!
Old Aug 19, 2008 | 08:08 PM
RedValve's Avatar
Default Re: sub install (phoshizzle88)
im sure v6performance.net or driveaccord.net has it somewhere. search it and see wat it gives you.
Old Sep 2, 2008 | 11:47 AM
geewa007's Avatar
i got a system installed in my car and kept the stock deck as well, what the guy did is tap the speakers with this device. I guess he got the audio to go from the headunit to the device and then to the speakers. The sub lines came from where the speaker lines came out of as well, but ran those lines to the back of the car. The brand of the device was called Absolute Audio, or something like that.
Hope that helped
Speed_69
11
Aug 25, 2010 11:11 PM
Sorcin
May 17, 2010 07:36 PM
dungsta
Audio / Security / Video
Jul 27, 2004 06:19 AM
swatdog
May 5, 2004 01:05 PM
Dark_Knight
Mar 7, 2004 09:45 PM
