Installing Subwoofer - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Old 05-27-2008, 11:50 AM
Speed_69's Avatar
Default Installing Subwoofer
Is it possible to install a subwoofer using the stock Honda Headunit on my 7th gen accord sedan? It has the 6 disc cd change. Or do I have to install an aftermarket headunit? I'm looking to get the Infinity Basslink.
If it is possible..is it possible to hook up a 4-way amplifier for my speakers using the same stock headunit?
Any information would be helpful..thanks!
Speed_69 is offline
Old 05-27-2008, 08:01 PM
ziwang55's Avatar
yeah im running on stock unit with 1200w infinity amp with 2 12inch infinity reference. its fine
ziwang55 is offline
Old 05-28-2008, 08:44 AM
H22a T13's Avatar
Default Re: (ziwang55)
so does that mean that there are RCA inputs on the back of the headunit or do you need an adapter?
H22a T13 is offline
Old 05-28-2008, 11:29 AM
ziwang55's Avatar
well i got everything set up at bestbuy cuz they know what to do. and yeah i got like an adapter sort of thing that i needed inorder for me to use my subs with a stock head unit. and the adapter thing was placed in the trunk right under the rear speakers.
ziwang55 is offline
Old 05-28-2008, 07:24 PM
str8venom99's Avatar
your gonna need a line converter and a remote trigger for the amp
str8venom99 is offline
Old 05-28-2008, 10:44 PM
Speed_69's Avatar
Default Re:
anybody have any experience using JL Cleansweep or Rockford Fosgate 3Sixty?
Speed_69 is offline
Old 08-11-2010, 02:04 PM
Default Re: Installing Subwoofer
what kind of adapter did you use and where couldi get one?
JR88 is offline
Old 08-12-2010, 10:16 AM
Yes it is possible, You can look up some adapters on ebay they are very inexpensive
xpehbam is offline
Old 08-12-2010, 11:13 PM
KWayRacing's Avatar
JR88 Its easy. search line to rca converter and there are 711,000 posts about the subject. read a bit
KWayRacing is offline
Old 08-22-2010, 03:49 PM
Be careful, many of these guys are strictly car guys but not car audio guys!
You can run off stock headunit but the amp output is a lot weaker than with an aftermarket headunit installed. Most audiophiles would consider this a waste of money since you really are limiting your system immediately from the source.
JL CleanSweep does work well and is maybe the easiest way to keep your stock headunit while maintaining performance from speakers/subs.
If you are serious about your system I would suggest a few weeks on the www.caraudio.com forums.
thefacta is offline
Old 08-25-2010, 09:28 PM
truckboy's Avatar
your going to need an amp, a wiring kit,
remote and rca from the cd player ran to the amp.
power wire through the firewall and then hidden by the trim .
ground wire no longer than 18 inches long then speaker wire to your amp.
for clarity you need an aftermarket reciever with rca output.
truckboy is offline
Old 08-26-2010, 12:11 AM
it is possible to install
bkindness is offline
amboyzfinest94
Acura TL, RL & ZDX
10-09-2011 08:06 AM
looney
10-06-2007 04:13 PM
HondaRcB
Audio / Security / Video
02-12-2006 01:46 PM
w1ck3dR
07-15-2005 04:27 PM
shamoo
10-18-2002 06:38 PM
Quick Reply: Installing Subwoofer
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
