help!! my brakes suck
Ok when my car is off, i hold my brakes and they travel to the floor. When the car is on it does the same thing but faster and i'll pump them and they'll build pressure but drop back down. I bled them a bunch of times but still the same thing. Any help will be apprieciated.
it sounds to me like there is a leak in the lines somewhere... check all the lines if they are leaking and also under the Master cylinder, check for any leakage
it sounds like the seal inside of the brake booster is bad take the brake booster out and push the center of it wher the peddle pushes the rod into it and if its spongy or soft its bad
Did you take of the rear drums to see if wheel cylinders are leaking? You could have a cut seal inside the master cylinder causing your condition. IF you got good pressure at a stop then the pedal slowly goes to the floor is a classic symptom of a bad master cylinder.
miataguy
Jul 8, 2003 09:00 PM
