Need help!!! 88 crx Wont start
I got a 88 CRX SI that wont start. Its got a D16z6 I just put in it. I have spark. When I start it, it starts but dies. It starts only for about one second then dies. I am trying to keep the car on an obd-0 ecu.
Modified by slickrickauto at 3:47 PM 8/16/2008
you can't use OBD1 distributor with OBD0 ECU - if you want to run it OBD0, you need OBD0 distributor - there are none that will bolt right on to a Z6 head
i would highly rceommend that you get a P28 OBD1 ECU and OBD0 to OBD1 ECU jumper and run it OBD1 - otherwise, you have no way to control fuel and ignition timing at VTEC engagement
filthyCREX
35
Feb 20, 2004 05:36 AM
