93 da gsr distributor
Old Aug 16, 2008 | 12:31 PM
Hanmin's Avatar
Default 93 da gsr distributor
bought my friend a re wired obd2-obd1 vtec distributor, and he gets a cel, I plug in my jumper and it doesn't blink, it just stays off.... Does that mean the ecu is fried??? im using an ls ECU(oops) because if i use the gsr one itll throw a knock sensor code, and i would rather not have that
Do you guys think the dizzy is wired wrong???? I just started the car, went to his house, turned off the car, switched the dizzys real quick and then started the car, it was fine, but after i put load on it the darn thing started to throw a code.
ill try a different ls ecu in a little bit.
Modified by Hanmin at 3:55 PM 8/16/2008
Old Aug 16, 2008 | 02:54 PM
Hanmin's Avatar
bump
Old Aug 17, 2008 | 01:44 PM
Hanmin's Avatar
wasnt a real problem, the ecu probably got confused for some reason. It stopped throwing a code after i let the car sit and started it up again.
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
turbob18si
Dec 3, 2006 04:02 PM
WesticLe
Sep 25, 2003 04:50 PM
SweetChin
Jun 3, 2003 01:18 PM
xci_ed6
Feb 28, 2003 03:01 PM
