*SEARCHED NO LUCK* ps conversion in 92 civic
I'm adding power steering to my 92 civic. Have two questions, hopefully someone could help.
1. The bracket on the passenger side doesn't fit on the rack and pinion from the manual rack and pinion, will I just need to get a new bracket from a ps r&p or do I need a new subframe also? LOOKS LIKE I NEED TO REPLACE MY SUBFRAME! THE HOLES AND BRACKET ARE DIFFERENT.
2. MOST IMPORTANT! Where do the wires go? I have the plug with about 8 in wire only and they are cut.
k, went to http://technet.ff-squad.com/wiring.obd1.htm and found that it's the B8 going to the ecu, but it claims it should be an empty slot, but its not. It has a wire going from the ecu to ??? anybody know? Any help on where the wire goes, it's going to be a pain digging through and following the wires.
plus anybody have a better quality wiring diagram than this? Could help me a lot:
thanks for any help I get.
Modified by murtnabila at 1:39 PM 8/16/2008
Modified by murtnabila at 2:25 PM 8/16/2008
updated some more...working on car now everything is in. Just need wiring help now
Pleaseeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Houston Hatchback
Aug 11, 2002 10:39 PM
