CORRECT way to take off 02 sensor...
Old Jul 23, 2002 | 08:56 AM
B16A2's Avatar
Default CORRECT way to take off 02 sensor...
i am installing a type one header with a carsound cat, and i wanted to know the correct way to take off the 02 sensor and to put back on.
the application is a 99 civic si.
thanks
Old Jul 23, 2002 | 08:58 AM
Johnny Tran's Avatar
Default Re: CORRECT way to take off 02 sensor... (B16A2)
CLAW HAMMER.
.....unplug,use a "crecent" wrench to loosen, reinstall in new header, plug in
Old Jul 23, 2002 | 08:59 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
I have a socket designed to take off O2 sensors. It's got a slit in the side to put the wire through.
Getting it unplugged was a bitch but that might have just been my car. The plugs were stuck solid.
Old Jul 23, 2002 | 09:00 AM
Back in Black's Avatar
Rather OG
Default Re: CORRECT way to take off 02 sensor... (Johnny Tran)
You may want to coat the threads with some anti-seize as well
Old Jul 23, 2002 | 09:05 AM
AssPenny's Avatar
Default Re: CORRECT way to take off 02 sensor... (Jason Franza)
Use fire
Old Jul 23, 2002 | 09:12 AM
Dave-ROR's Avatar
with a wrench.
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: CORRECT way to take off 02 sensor... (AssPenny)
teeth
Old Jul 23, 2002 | 09:21 AM
reefer_bob's Avatar
Default Re: CORRECT way to take off 02 sensor... (newt2)
Bingo! With a little penatrating oil on the threads before hand, and the Anti-Seize afterwards!
Old Jul 23, 2002 | 09:30 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: CORRECT way to take off 02 sensor... (reefer_bob)
I believe Bosch makes said socket. I know I've seen it in Volvo catalogs (assuming they are universal).
You can buy a lot of beer and a crecent wrench for the cost though
Old Jul 23, 2002 | 10:04 AM
reefer_bob's Avatar
Default Re: CORRECT way to take off 02 sensor... (Splat)
Snap-On, Craftsman... they all make one...
Old Jul 24, 2002 | 11:10 AM
B2FiNiTY's Avatar
I just used a open ended 23mm or 1/2 wrench.
Old Jul 24, 2002 | 11:12 AM
Asahi's Avatar
Default Re: CORRECT way to take off 02 sensor... (B2FiNiTY)
I think you mean 22mm. Me too. I don't like the O2 sockets
edit: 24.5mm is 1"
22mm is much bigger than 1/2"
[Modified by Asahi, 2:19 PM 7/24/2002]
Old Jul 24, 2002 | 11:14 AM
B2FiNiTY's Avatar
Default Re: CORRECT way to take off 02 sensor... (Asahi)
Well, I just used a 1/2 but I forgot what was the metric version.
Old Jul 24, 2002 | 11:20 AM
Asahi's Avatar
See my edit. 22mm is bigger than 1/2" Double check. I do use a 22mm for sure. I belive the standard size is 7/8"
Old Jul 24, 2002 | 11:22 AM
B2FiNiTY's Avatar
Oh wait. Yeah I used 7/8 which was the largest one I had. I remember that 22mm is the correct size. x1278612983 on me
zapzach
May 10, 2010 09:18 AM
xci9v8icx
14
Jun 14, 2009 03:58 PM
bigslimdog
25
Mar 18, 2004 12:08 AM
B16A2
12
Oct 27, 2002 06:43 PM
B2FiNiTY
Jun 21, 2002 02:07 PM
