correct way to take 02 sensor off and back on...
Old Jul 23, 2002 | 08:54 AM
B16A2's Avatar
Default correct way to take 02 sensor off and back on...
i am installing a type one header with a carsound cat, and i wanted to know the correct way to take off the 02 sensor and to put back on.
the application is a 99 civic si.
thanks
Old Jul 23, 2002 | 08:58 AM
DragII's Avatar
25 Year Member
Default Re: correct way to take 02 sensor off and back on... (B16A2)
unhook electrical connector, unscrew sensor.
screw sensor back in, reconnect electrical connector
Old Jul 23, 2002 | 09:04 AM
B16A2's Avatar
Default Re: correct way to take 02 sensor off and back on... (DragII-Sellout)
so i unhook the electrical connector before the stock header is taken out...
then i take out the stock header with the sensor still in it...
so then i take out the 02 sensor from stock header then put it onto the type one...
then i intall header with the 02 sensor already on it ...
then i put the electrical connector back on after the header is intalled.
is this the right way?
thanks.
Old Jul 23, 2002 | 09:09 AM
JeffS's Avatar
Yes, that will work...
Are you sure you're licensed to operate a wrench?
Old Jul 23, 2002 | 09:12 AM
DragII's Avatar
25 Year Member
Default Re: correct way to take 02 sensor off and back on... (JeffS)
LOL
ya man that's all there is to it.
Old Jul 23, 2002 | 01:26 PM
Evs-One's Avatar
Solbros Owns Me
sometimes those can be a big pain..
Old Jul 23, 2002 | 02:07 PM
Jackson's Avatar
Use a 22mm open-end wrench. "Lefty Loosey...Righty Tighty"
Old Jul 23, 2002 | 02:12 PM
Briman2021's Avatar
Default Re: correct way to take 02 sensor off and back on... (Jackson)
whatever you do, dont break them, they are expensive, use a **** load of wd-40 before you think about using a breaker bar.
BTW, I broke the one in the cat, and i had to replace it. I used a $60 universal one, it works fine, so if oyu do happen to break your downstream 02 sensor, im me and i will tell you how to save $240 by buying a unversal and crimping some wires.
Old Jul 24, 2002 | 11:39 AM
B16A2's Avatar
Default Re: correct way to take 02 sensor off and back on... (Briman2021)
thanks alot. well i just did the install last night, everything went smoothly exept for the placement of the bung hole on the carsound cat... it is really close to the stabalizer bar near the shift linkage im hoping that it will not get damaged, but so far so good with the 02 sensors.
but... i started hearing a rattling sound and i checked it out, it was not the cat it is one of the springs. i haven't tried anything yet, is there anything anyone can suggest?
Old Jul 24, 2002 | 12:54 PM
Briman2021's Avatar
Is it one of the springs around the bolt on the back of the cat??
If so, just torque it down some more, that happened to mine a while ago, i guess it came loose just by being used for 5 years. I dunno, just try tightening it some more, and if that doesn't work, no harm done.
Good Luck!!
Old Oct 27, 2002 | 04:33 PM
ruthless013's Avatar
bung hole
Old Oct 27, 2002 | 05:07 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: correct way to take 02 sensor off and back on... (ruthless013)
Why in the world did you have to bring this pointless 3 month old thread back just to quote "bung hole". Whatever happened to doing something productive with your time rather than going through 50 pages of HT history
Old Oct 27, 2002 | 06:43 PM
1 speedstar's Avatar
Default Re: correct way to take 02 sensor off and back on... (Emerica)
lol... yah why the hell did you do this?
4drteg54321
Jan 27, 2009 01:28 PM
Ricey McRicerton
Oct 15, 2004 11:09 AM
130R
14
Jul 8, 2004 03:58 AM
Brasspremier
Dec 26, 2002 05:28 PM
B2FiNiTY
Jun 21, 2002 02:07 PM
