Del Sol Projector HID's
Old Aug 16, 2008 | 08:04 AM
itsmejto's Avatar
Default Del Sol Projector HID's
OK, we all know the headlight beam patern from the Del Sols get you more flashes from oncoming drivers than any vehicle on the planet. They spill light in all directions but down in front of you, on the road don't they.
There are a few threads here, but nothing of any real value.
I've rearched the net and cannot find any for sale.
So I guess it's make em yourslef time.
Has anyone and information which units fit best.
Also it must have hi-low capability either a solenoid positioner or a simple halagen for high beam.
Anyone have any thoughts ?
Old Aug 16, 2008 | 08:14 AM
mattyfo0z's Avatar
Default Re: Del Sol Projector HID's (itsmejto)
Have you looked at the Lighting forums by any chance?
Old Aug 16, 2008 | 09:11 AM
itsmejto's Avatar
Default Re: Del Sol Projector HID's (.mattyz_)
I've searched many times but got nothing of any real use. Seems the search function isn't too good.
I'll check the loighting forum manually, thanks for the suggestion.
Old Aug 20, 2008 | 02:31 PM
MrRicey's Avatar
If you are looking to do a HID retrofit on the headlight I suggest you go do your researching at HidPlanet.com/forums. They have lots of experienced retrofitters that could answer your question.
About have hi and lows you can buy Bi-Xenon projectors and retrofit them into your headlights and still retain both your low and high beam. Its a simple process of just hooking up your high beam wires to a solenoid to activate the high beams.
I'm might be buying a del sol soon and if I do I'm going to do a HID retrofit on it. I'll create a thread if you are interested..
Old Aug 20, 2008 | 05:09 PM
Infinity_Racer's Avatar
Default Re: (MrRicey)
I would just go with a retrofit. It'll be much worth it.
Here's an ebay del sol headlight i retro'd for a friend using fx35 bixenon's and i just made my own wiring harness so it can use low/high beams.
Old Aug 21, 2008 | 07:04 AM
itsmejto's Avatar
Default Re: (Infinity_Racer)
Just perfect , I have some fx35 projectors coming.
Do you think you might give some more info on positioning of them into the reflectors.
I'm planning on using a pair of jdm's which were of little use before.
More photos ?
Old Aug 21, 2008 | 07:36 AM
itsmejto's Avatar
I did find this interesting.
http://hondaswap.com/body-exte...95475/
Old Aug 22, 2008 | 02:10 PM
itsmejto's Avatar
Looks good, give us more, I'm ready to go on this.
One question, I have the solenoid plug from a wiring harness from an fx35 but need to know what exactly drives the coils, is it 12vdc through a realy from the hi beams, or some other off the wall method from the ecu (like 5vdc) . I don't want to burn things up before I get em on the road.
Old Aug 22, 2008 | 02:11 PM
itsmejto's Avatar
Not sure how this thread got into the accord section, but will a king op please move it to the del sol or lighting threads for us.
Old Aug 25, 2008 | 07:50 AM
Coomer's Avatar
I'd just do a projector retrofit as well. I loved mine when my Sol was on the road.
Oh yeah, mine are for sale if anyone's interested.
Modified by Coomer at 9:23 AM 8/25/2008
Old Aug 25, 2008 | 10:58 AM
Agent_EM1's Avatar
Default Re: (Coomer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coomer &raquo;</TD></TR><TR><TD CLASS="quote">I'd just do a projector retrofit as well. I loved mine when my Sol was on the road.
Modified by Coomer at 9:23 AM 8/25/2008</TD></TR></TABLE> That's sick
Old Aug 31, 2008 | 03:52 PM
itsmejto's Avatar
any more diy info ?
Old Aug 31, 2008 | 04:26 PM
Coomer's Avatar
What do you want to know exactly? There are tons of how-tos out there.
BlackSol07
Sep 14, 2007 11:17 AM
sir2sol
Feb 5, 2007 05:16 PM
Crasian
Dec 18, 2006 03:07 PM
sir2sol
10
Nov 13, 2006 08:50 AM
STooK02780
Sep 28, 2004 05:41 PM
