Car leaking water and overheating SOme HELP !!!!
Old Aug 15, 2008 | 10:11 PM
zcmotor's Avatar
Default Car leaking water and overheating SOme HELP !!!!
ok i got my car back yesterday where a shop just pulled out the front end . The Radiator got Cracked so i replaced it but now the car is leaking all the AntiFreeze i put on there. I believe i see it leaking by behind the manifold but not sure. Could it be the radiator ????? some help here Yoooo.. i have a 88 civic.....
Old Aug 15, 2008 | 10:22 PM
91EF9hatch's Avatar
Default Re: Car leaking water and overheating SOme HELP !!!! (zcmotor)
if you replaced the radiator than it should be fine, i would recheck all your hoses and see if they need to be replaced or simply tighten better.
Old Aug 15, 2008 | 10:29 PM
zcmotor's Avatar
Default Re: Car leaking water and overheating SOme HELP !!!! (91EF9hatch)
yes the radiator. i hit a car my car got messed up just from the front bumber and the radiator cracked. so replaced it and so maybe about 20 mins of driving it starts to over head and water leaks everywhere. The hoses i didnt change them i just see water all over when i open my hood. Lol
Old Aug 15, 2008 | 10:43 PM
dohczccrx's Avatar
you see it leaking from behind what manifold. if its leaking you should be able to see where its leaking from, and fix it
Old Aug 15, 2008 | 10:47 PM
zcmotor's Avatar
Default Re: Car leaking water and overheating SOme HELP !!!! (dohczccrx)
well i dont know if its coming from the drips that was all over the hood plus i cant really see it in the night time cuz in the day i have no time but ill see it in the morning.
Old Aug 17, 2008 | 06:41 AM
beige89civic's Avatar
* B A N N E D *
Sounds like a leaking water pump. If it's below the left part of the intake manifold, and by the altenator bracket, it's the water pump.
Old Aug 17, 2008 | 07:23 AM
zcmotor's Avatar
Default Re: Car leaking water and overheating SOme HELP !!!! (beige89civic)
i already fix the problem it was a shaped hose that was by the dizzy and manifold. But now another hose got a hole so its leaking but im going to replace it right now. Thanks people
Jen Hoffert
Mar 28, 2016 07:47 PM
nadana
11
Jul 22, 2012 01:08 PM
eg_21
11
Jan 4, 2010 09:03 PM
tbonez
Feb 9, 2007 05:53 AM
Brian-Brian
Jun 20, 2003 03:11 PM
