91 integra wont turn over
Old Aug 15, 2008 | 06:56 PM
c5stunna's Avatar
Default 91 integra wont turn over
so i have a 91 integra thats runnin a 98 gsr swap. it was running good then i did a cam and i/m swap. now when i turn the igniton on and then to start i just hear a clicking from what sounds like in the heater area. i do have a auto page alarm that works, ive tried unpluging it completly, had my starter checked it works, grounds are grounded and fuses are good. i do hear my fuel pump pumping as well? idk what it could be im stumped......
Old Aug 16, 2008 | 01:43 AM
GoCarInteg's Avatar
Default Re: 91 integra wont turn over (c5stunna)
u sure you didn't put the dizzy on 180?
Old Aug 19, 2008 | 11:00 AM
c5stunna's Avatar
Default Re: 91 integra wont turn over (GoCarInteg)
yea cuz i think it only goes in one way
Old Aug 19, 2008 | 02:41 PM
vtecb18c's Avatar
your dizzy does not go on one way..yes it sits in the head one way but it can be adjusted and its possible its not timed right..try loosening the bolts and spin it as the car is being cranked...its hard for me to explain what im trying to say but you should catch my drift
Old Aug 19, 2008 | 04:39 PM
GoCarInteg's Avatar
Default Re: 91 integra wont turn over (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">your dizzy does not go on one way..yes it sits in the head one way but it can be adjusted and its possible its not timed right..try loosening the bolts and spin it as the car is being cranked...its hard for me to explain what im trying to say but you should catch my drift </TD></TR></TABLE>
in other words, if you took your dizzy off, just turn it 180 degrees.. i wouldn't try cranking while the dizzy though.
Old Aug 19, 2008 | 05:04 PM
PatrickFrantz's Avatar
mine sis the same thing as well but i got to looking around an i found that my starter plug was disconnected
sageice
Aug 21, 2009 02:05 AM
jdmkid8383
Feb 11, 2007 03:41 PM
import_racer_ky
Jul 20, 2003 05:20 PM
import_racer_ky
Jul 19, 2003 08:49 PM
