91 DA HAVING TROUBLE STARTING
MY 91 DA STARTS HERE AND THERE WHEN i leave in the morning for work it wont start it clicks but no start I replaced the starter for a used on because the old one was trash and I had to bang on it to start. But now Im having the same problem. She starts up sometimes but most of the time I have to push start it. lol I need help Da heads
Before wire tuck
After
Before wire tuck
After
Re: 91 DA HAVING TROUBLE STARTING (jdmkid8383)
I would take off the starter that you have and get it bench tested to make sure it is working correctly. I would go from there.
Re: 91 DA HAVING TROUBLE STARTING (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee »</TD></TR><TR><TD CLASS="quote">should have bought a new one
tuck looks good </TD></TR></TABLE>
+1 you should've went new, who knows you may've been unlucky and got another bad one.
Re: 91 DA HAVING TROUBLE STARTING (integrada9)
Have your battery and alternator tested while you get the starter tested i had a battery problem and the the car acted asthough the starter was bad even though it was barnd new. replaced the battery and alternator and it ran fine.
thanx guys Ill be looking at the DA somtime this weekend and do some test. Its been starting fine allday. Did alot of running around for the Ibach meet. Who went!!!!!!!!!!!
Re: (adamrich33)
Make sure you got the right wire for you batteyr relocate. Its Battery wire (thicker copper wires inside) This may be the cause of your starting problems. toue running alot longer wire to your trunk and it takes alot of amperage tog et it there
daviduhley
02-10-2013 08:33 PM
