Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
ls/vtec for sale cheappppppppp
Old Aug 15, 2008 | 05:21 PM
nikkarocky's Avatar
Default ls/vtec for sale
i have a ls/vtec setup where the rod is not connected to the crank in the driver side cylinder..so im not sure of what damage it has done to the cylinder wall...motor still cranks but there is a nasty slapping noise..with that explained everything else on the motor works great.
most the parts that are installed have less then 100 miles on them.
b16 head 20,xxx mile
ls cometic 3mm head gasket
arp head bolts
aem adjustable cam gears
head got resurfaced and mild mill
new valve stem seals
golden eagle ls/vtec kit
skunk2 im w/hondata im gasket (comes with fuel rail, dizzy, and maybe injectors depending on my other swap)
stock tb
(will not have an air intake temp. sensor)
new gsr(p72) timing belt and water pump
b18b block with 90,xxx miles
will throw in new arp rod bolts
ls tranny 90,xxx miles
3rd grinds with high rpm's
comes with exedy pressure plate with a ATC street disc
im asking 850 for the swap..it does not come with ecu, axles, shiftlinkage, and maybe the injectors
also for sale is a b18b head with no dizzy nor injectors
but it does come with a edelbrock performer x im w/hondata im gasket 90,xxx miles
there is a small chip where the tb and im connects but it doesnt effect anything when i used it
asking 350.00
i also have two bare stock b16 im and one bare b18b im
if you want to buy everything ill do it for 1000.00
txt or call me at 682 521 5945
only thing im looking for is a milano red si lip and skunk2 gsr im
Modified by nikkarocky at 12:24 PM 8/17/2008
Modified by nikkarocky at 10:31 PM 8/18/2008
Modified by nikkarocky at 6:16 AM 8/19/2008
Old Aug 15, 2008 | 11:43 PM
nikkarocky's Avatar
bump
Old Aug 17, 2008 | 09:28 AM
nikkarocky's Avatar
nobody wants ittt? its out of my car now come and get itttt its ob
Old Aug 19, 2008 | 03:15 AM
nikkarocky's Avatar
bumppp
Old Aug 24, 2008 | 08:54 PM
nikkarocky's Avatar
750.00 obo for lsvtec and tranny
Old Aug 26, 2008 | 01:31 PM
nikkarocky's Avatar
bumpppp obo
Old Aug 28, 2008 | 01:31 PM
nikkarocky's Avatar
Default Re: (nikkarocky)
bumppppp somebody buy meeeeee
Old Aug 30, 2008 | 12:34 PM
nikkarocky's Avatar
bump
pooorman's type-r
15
Oct 4, 2009 01:36 PM
string
Aug 21, 2006 07:46 AM
hotimportcrx
Northeast (Sales)
Mar 27, 2006 06:51 PM
crxsimike
Feb 14, 2006 12:07 AM
hatchmonkey92
May 5, 2005 09:25 AM
