Hydro carbon
Old Aug 15, 2008 | 04:13 PM
dc2king's Avatar
Default Hydro carbon
i got my 98 integra gsr smogged today and i failed. i failed because my car is letting out too much hydro carbons?? i dont know what that means and i dont know what to do! please help!!!! (o btw i live in california.)
Old Aug 15, 2008 | 05:33 PM
TunerN00b's Avatar
Default Re: Hydro carbon (dc2king)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2king &raquo;</TD></TR><TR><TD CLASS="quote">i got my 98 integra gsr smogged today and i failed. i failed because my car is letting out too much hydro carbons?? i dont know what that means and i dont know what to do! please help!!!! (o btw i live in california.)</TD></TR></TABLE>
If your car is stock, take it to the dealer. High HC on a stock car can mean the cat is failing or has already failed, and they are required to replace it under warranty (smog equipment has an extended warranty).
If you're modified, then its your tune. High HC is unburned fuel, meaning its running rich.
Old Aug 17, 2008 | 09:55 PM
dc2king's Avatar
Default Re: Hydro carbon (TunerN00b)
it has intake, header, exhaust, intake manifold, cam gears. and i just replaced the spark plugs. and the guy i bought it from said he supposedly just got a new cat. what do i do about the unburned fuel??
Old Aug 18, 2008 | 08:53 AM
Evs-One's Avatar
Solbros Owns Me
HC is partially burned fuel.
Warranties on cats are only 8yr/80k miles.
Why was it sniffed when it's OBD2?
Old Aug 18, 2008 | 02:51 PM
TunerN00b's Avatar
Default Re: Hydro carbon (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">
I thought it was longer for smog equipment. Maybe I should burn a tank of leaded fuel now, since I'm about to hit the 75k mile mark, and get a free cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">Why was it sniffed when it's OBD2?</TD></TR></TABLE>
CA does a sniffer test, regardless of OBD version.
Upsets me too. My 00 GSR barely passes (34/49 HC measured, 35/50 permitted), and its stock other than an AEM CAI.
Old Aug 18, 2008 | 03:05 PM
Evs-One's Avatar
Solbros Owns Me
CA is too crazy for me
Old Aug 18, 2008 | 05:44 PM
kisses's Avatar
Yep, HC and the ride should be compatible too. I've seen lots of cars that were emmiting lots of HC when revving up and I think that's normal. If you have stock parts, be careful it might cause another problem in your car.
____________________
Autopartswarehouse is a must!
Old Aug 18, 2008 | 07:32 PM
dc2king's Avatar
so what should i do then? my friend told me to run the cat hella hot and to put denatured alcohol in the gas tank. im also gonna put my stock exhaust back on.
Old Aug 18, 2008 | 09:22 PM
dtapia's Avatar
can you give us some readings from the sheet.
Old Aug 19, 2008 | 07:49 AM
srmofo's Avatar
Default Re: Hydro carbon (dtapia)
first make sure the guy didnt [freak] you, check to see if it even has a cat on it, let alone a new one....running alcohol will cause the motor to run hotter burning off the extra fuel,but if it gets too hot while they are testing it they will shut the car off, which [freak]s up the whole damn test and then you are back to square 1
Old Aug 19, 2008 | 02:49 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2king &raquo;</TD></TR><TR><TD CLASS="quote">so what should i do then? my friend told me to run the cat hella hot and to put denatured alcohol in the gas tank. im also gonna put my stock exhaust back on.</TD></TR></TABLE>
This dropped HC by 33% on a 1988 Civic. Took it from gross polluter fail to pass.
Pep Boys carries it.
Denatured alcohol helps burn as well. Though, this is what I'd use instead.
It is a gas line anti-freeze, but lowers combustion temp and ends up reducing HC a little and NOx a lot.
Old Aug 19, 2008 | 04:11 PM
srmofo's Avatar
iso heet is denatured alcohol, although there is 2 different kinds, just read the label to make sure your getting the right one, the other is in a blue bottle and I think it is methylated alcohol? not 100% sure ,its been a while
Old Aug 19, 2008 | 04:22 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Hydro carbon (srmofo)
i believe that the cat is the main part of the prob.
Old Aug 19, 2008 | 11:07 PM
dc2king's Avatar
Default Re: Hydro carbon (Egezzy)
i just bought some denatured alcohol and im gonna go smog it agian it tomorrow morning. also the cat that i have is an aftermarket stock one.
Old Aug 20, 2008 | 08:39 AM
dmotoguy's Avatar
e85 works too..
Old Aug 20, 2008 | 06:50 PM
black93octane's Avatar
Default Re: Hydro carbon (dmotoguy)
even though hho is a little over rated it will help emissions
aelixir
Mar 15, 2017 08:21 PM
JDM 98 GSR
Nov 2, 2008 12:40 PM
95TegSE
Dec 30, 2006 07:24 AM
iniquitous
Nov 1, 2004 06:12 PM
jwlmike
24
Aug 8, 2003 05:06 PM
