Question about All Motor FP
440cc injectors, Pro series fuel rail , B&M Adjustable FPR , gauge is dead on.
Motors around 11.8~12.0CR all motor build its street tuned right now but i had a question to what fuel pressure you guys suggest i just was throwing this in the air.
At idle its around 45psi with vacline on, during WOT it bumps to around 48ish or so.. suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Whatever it was tuned with. I like 50 psi @ no vacume. Not sure why, just seems to have good responce there.</TD></TR></TABLE>
Thx done so
What do you suggest i unplug the vac line and plug that line in the back of the pX manifold?
Thx done so
By no vacume I was refering to WOT. Set it with the vac. line pluged, then hook it up for idle. 40-45 is good for idle, or what ever you get, tune it there.
Thx again donf, whats your thoughts on running it without a vac line any reason to keep the vac line on?
</TD></TR></TABLE>Thx again donf, whats your thoughts on running it without a vac line any reason to keep the vac line on?
Jan 5, 2005 12:20 PM
