FS--KS-- Tial,ACt,Garrett,Boost stuff B series
will trade for ---
B18 or b20 all motor bottom end -- high comp pistons and rods sleeves a plus
B16 built head aftermarket valve train no oversized valves tho
hytech or other top end header
stage 2 cams or bigger
traction bar
Garrett 57 Trim t3/t4-- $540 BRAND NEW
Compressor Specs:
- T04E housing 2-3/4" inlet 2" outlet
- 57 trim T04E compressor wheel 2.23/2.95 45lb/min
Turbine Specs:
- T31 4 bolt outlet turbine housing .63A/R ratios
- 76 trim T31 turbine wheel (stage 3)
Tial 50mm BOV-- $220 brand new
Tial 38mm wastegate-- $220 brand new
Tial 10lbs spring yellow-- $33 new
Meutek Bseries manifold -- $130 Brand new
3" Downpipe 4bolt-- sold
rc autoworks i/c piping -- $130 brand new
T bolts and couplers 2" and 2.25" -- $100 brand new
**450 dsm injectors w/resistor box-- $110
Frount mount intercooler-- 160 brand new
Stealthmode Oil kit-- $100 brand new
**Skunk2 short throw--
**70mm BBK tb--- $200
**JG B16 intake manifold-- $250
Dump Tube and elbow-- $50 new
**B series vtec Solenoid assembly-- $75.00
Findanza flywheel 8lbs-- $190 brand new
**ACT extremme PP and 6 Puck unsprung disc-- $250
** <-- mean its used but in great working order
27" x 7" x 3.5" dimesnions
Modified by levee000 at 3:07 PM 8/24/2008
Modified by levee000 at 7:15 PM 8/24/2008
traction bar
Compressor Specs:
Turbine Specs:
specs are Compressor Specs:
Turbine Specs:
- T31 4 bolt outlet turbine housing .63 A/R ratios
Brand NEW
Turbine Specs:
Brand NEW
Maveric
Jul 12, 2007 08:04 AM
parting out sfwd/t4 car...lots of goodies....full-race, tial, innovative, strange suspension,z10 wet
miller
Oct 19, 2005 09:17 PM
ArizonaTurbo
Jan 4, 2003 09:48 AM
