Hey Guys Just a Couple Questions
1st Will This Engine Swap Into My 86 CRX easily?
"88-91 HONDA CIVIC EF DOHC 1.6L NON VTEC OBD0 ENGINE -ZC" it's on Ebay for 750 bucks..
was also wondering if this is a good price and if there are any better swaps out there available?
dude there are plenty of engine places located in ga that you dont have to get one off Ebay.
I picked mine up for $500 from a place in tucker.
since yours is a 86 there are mounts you have to use with specific engine combinations.
I think hasport makes the mounts for your car with a b series engine.
have you tried red pepper racing they are all about 1st gen civics and crx's
https://honda-tech.com/zerothread/2030720
umm im not far from tucker.. cartersville/rome/barrett parkway area ... umm i had been doing some research and i couldve sworn there was a direct bolt in motor, like the black top ZC motors.. if this is true, which year model integra's should i be looking for, cause we have quite a few junk yards around here.. ty for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White86CRXSi »</TD></TR><TR><TD CLASS="quote">umm im not far from tucker.. cartersville/rome/barrett parkway area ... umm i had been doing some research and i couldve sworn there was a direct bolt in motor, like the black top ZC motors.. if this is true, which year model integra's should i be looking for, cause we have quite a few junk yards around here.. ty for the help</TD></TR></TABLE>the 88-91 DOHC ZC engine will not bolt into a 1g CRX - the JDM 85-87 "browntop" DOHC ZC from 85-87 JDM 1g CRX Si and 3g Civic Si will bolt right in - the 86-89 USDM Integra D16A1 (which is not a ZC, but similar to the "browntop") will bolt right in - you would need to use the 86-89 Integra transmission, intermediate shaft, axles, knuckles/hubs and shift linkage along with the Integra ECU - the 86-87 Integra D16A1 is a little easier to swap since it had the vacuum advance ignition like the 1g CRX - 88-89 D16A1 require more wiring for the electronic ignition advance, but can be done
djnikko
Aug 22, 2004 06:32 AM
