Made Wastegate Dump Last night... Critique...
Old Aug 15, 2008 | 09:36 AM
dmotoguy's Avatar
Default Made Wastegate Dump Last night... Critique...
Tell me how to improve my welds before I do my downpipe...
this was my first real welding project with stainless.. it welds nice.
it was on a miller 180 @80amps not full pedal ever... w/ gas lense
Old Aug 15, 2008 | 01:44 PM
.john.'s Avatar
Default Re: Made Wastegate Dump Last night... Critique... (dmotoguy)
seems like it would have been better to route it down the exhaust side away from the intake. the welds look a bit cold but i think a smaller filler rod would help you to even out the "lumpiness" of the welds. what size filler rod are you using?
Old Aug 15, 2008 | 02:06 PM
CSaddict's Avatar
Hard to believe you strapped such a nice wastegate to such a pile of **** manifold.
Old Aug 15, 2008 | 02:45 PM
dmotoguy's Avatar
Default Re: (CSaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CSaddict &raquo;</TD></TR><TR><TD CLASS="quote">Hard to believe you strapped such a nice wastegate to such a pile of **** manifold.</TD></TR></TABLE>
its temporary... im building a topmount after I get my car running...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .john. &raquo;</TD></TR><TR><TD CLASS="quote">seems like it would have been better to route it down the exhaust side away from the intake. the welds look a bit cold but i think a smaller filler rod would help you to even out the "lumpiness" of the welds. what size filler rod are you using?</TD></TR></TABLE>
I might change that placement.. i need to get my downpipe/radiator situation figured out.. i hope I have room for it all...
the rod was super thin.. maybe it was technique, im new to this.. thanks for the suggestions.
Old Aug 15, 2008 | 03:05 PM
integraturbo96's Avatar
it will work well but it look better with mandrel bend and i'm not a big fan of pizza cut
Old Aug 15, 2008 | 06:05 PM
ebydrc's Avatar
Banned
Default Re: (integraturbo96)
pie cuts adds 10hp though
Old Aug 15, 2008 | 06:14 PM
KENetics1's Avatar
Default Re: (ebydrc)
he should have added more pie cuts then
Old Aug 15, 2008 | 10:16 PM
DESTROYER's Avatar
if it dumps the waste gas, then whatev
Old Aug 16, 2008 | 02:15 PM
90blackcrx's Avatar
Default Re: (DESTROYER)
Lets see the inside, that tight bend could be a problem if your boosting low psi.
Old Aug 16, 2008 | 02:55 PM
dmotoguy's Avatar
Default Re: (90blackcrx)
the pie cut bend is only ~30 deg, then the other one is a 90.
Its mostly a drag car... there will be no low boosting...
Old Aug 16, 2008 | 03:40 PM
90blackcrx's Avatar
Default Re: (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">the pie cut bend is only ~30 deg, then the other one is a 90.
Its mostly a drag car... there will be no low boosting... </TD></TR></TABLE>
Ok, I know the bend is not bad but coming right off that outlet usually restricts the opening.
Old Aug 17, 2008 | 09:21 AM
.john.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Ok, I know the bend is not bad but coming right off that outlet usually restricts the opening. </TD></TR></TABLE>
also having the dump so long can have a negative effect on boost control. the longer the dump tube is, the more restriction it has, and the more possibility of boost spike/creep.
Old Aug 17, 2008 | 10:10 AM
dmotoguy's Avatar
Default Re: (.john.)
one I get my dp done I'm going to re-do it to go down the other side.. should be able to cut almost a foot out of it lol... thanks for the tips guys.
Old Aug 17, 2008 | 10:24 AM
90blackcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">one I get my dp done I'm going to re-do it to go down the other side.. should be able to cut almost a foot out of it lol... thanks for the tips guys. </TD></TR></TABLE>
Also with the 44mm, you can use bigger pipe if you need to. We did one with 2 inch pipe, was running very low boost on a high comp setup
Old Aug 17, 2008 | 11:29 AM
dmotoguy's Avatar
I might also put a megaphone at the end..
Old Aug 18, 2008 | 03:44 PM
JShull's Avatar
I'm curious as to why you had it go over and down the driver side like that and not keep it close to the downpipe? Just kinda wondering.
Edit: just read your other post haha. Reading owns me.
Old Aug 18, 2008 | 05:37 PM
91TSiGuy's Avatar
Default Re: (JShull)
70-80 amps on the flange is ok, but on the thinwall tubing I'd turn it down to 35-45 amps and .045" filler, but that's just how I do it. You may have better luck at first with 1/16 filler until you find your own technique.
Old Aug 19, 2008 | 12:24 PM
9295EJ-t's Avatar
do shorter incriments of welding so you can keep gas coverage over red hot material, instead of moving as fast and as far as possible..
also, my favorite cup to do work with is a #8.. it covers about half an inch of material, as oppose to some of the other cups like a #4 which covers only about a 1/4"
Old Aug 19, 2008 | 04:41 PM
Desir Performance's Avatar
also having the dump so long can have a negative effect on boost control. the longer the dump tube is, the more restriction it has, and the more possibility of boost spike/creep.</TD></TR></TABLE>
I have never heard of this, If anything the tuner Jeff Evans (Boosted Hybrid on this board) wrote a write up on how having a dumptube to short can actually hinder HP. Jeff encourage his customer to rout the dump tube under the oil pan.
Old Aug 20, 2008 | 07:39 PM
9295EJ-t's Avatar
the longer the dump is, the more likely the exhaust will not get sucked back into the turbo...
sykotik sol
Aug 18, 2008 02:38 PM
DESTROYER
Welding / Fabrication
20
Sep 3, 2007 11:27 PM
Wilky
Nov 3, 2006 05:51 AM
T3k C
Oct 10, 2006 02:08 PM
Egone
Feb 6, 2004 02:28 PM
