T1R test pipe, where do you plug the sensor?
Old Aug 15, 2008 | 08:56 AM
Tiger_Si's Avatar
Default T1R test pipe, where do you plug the sensor?
anybody running the T1R test pipe?
where do you plug the O2 sensor? and / or how would you go on fixing a CEL?
i searched, no solution...
Old Aug 15, 2008 | 08:59 AM
EG6-DC2's Avatar
Default Re: T1R test pipe, where do you plug the sensor? (Tiger_Si)
They don't have an O2 sensor hole. You would need to have an O2 simulator or take it to a shop and have them weld an O2 bung on there.
Old Aug 15, 2008 | 09:27 AM
totsie7944's Avatar
Default Re: T1R test pipe, where do you plug the sensor? (EG6-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">They don't have an O2 sensor hole. You would need to have an O2 simulator or take it to a shop and have them weld an O2 bung on there.</TD></TR></TABLE>
Exactly, just get a 02 bung welded on. Shouldn't cost too much at all.
Old Aug 15, 2008 | 09:33 AM
Tiger_Si's Avatar
Default Re: T1R test pipe, where do you plug the sensor? (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly, just get a 02 bung welded on. Shouldn't cost too much at all.</TD></TR></TABLE>
is that going to work?
should i weld it on the edges (thin part of the pipe) or on the middle of the pipe?
thanks for the input
Modified by Tiger_Si at 3:51 PM 8/15/2008
Old Aug 15, 2008 | 09:39 AM
EG6-DC2's Avatar
I would think it would have to be on the edges. Seeing that the main body is a resonator and might have some sort of filling. You will also need to push the O2 sensor out of the direct path of the exhaust.
Old Aug 15, 2008 | 09:43 AM
totsie7944's Avatar
Just get it welded onto the part of the pipe before the resonator where its just hollow piping. If need be you can buy a 02 sensor wire extender to reach if the stock one comes up slightly short, depending on where you get it welded.
Old Aug 15, 2008 | 09:54 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiger_Si &raquo;</TD></TR><TR><TD CLASS="quote">
should i weld it on the edges (this part of the pipe) or on the middle of the pipe?
thanks for the input</TD></TR></TABLE>
I did this same thing with an old T1R pipe that I had. Have the bung welded on the pipe next to the connecting flange. You can put the bung exactly where the stock location is at. The bung alone will not solve your CEL problem though. You will need to get a o2 sim fix for that problem.
Old Aug 16, 2008 | 09:17 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: T1R test pipe, where do you plug the sensor? (get RIGHT)
I did this same thing with an old T1R pipe that I had. Have the bung welded on the pipe next to the connecting flange. You can put the bung exactly where the stock location is at. The bung alone will not solve your CEL problem though. You will need to get a o2 sim fix for that problem.</TD></TR></TABLE>
or the spacers that screw into your stock location and then the o2 on top of that
Old Aug 16, 2008 | 09:34 AM
fastcrvi's Avatar
1. pay $20 to exhaust shop to weld an O2 sensor bung
2. pull it on the inside, keep it plugged in and wrap in aluminum foil
3. purchase O2 simulator
IntegraCF21
Sep 24, 2005 04:42 AM
TypeR864
Sep 22, 2005 08:23 AM
eLeCtRoNSi00
Mar 1, 2005 07:25 AM
Variable J
May 17, 2004 06:40 AM
madhatter07
Aug 9, 2003 06:30 AM
