Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheel Size
Old Aug 15, 2008 | 07:44 AM
Gong Show's Avatar
Default Wheel Size
I have a 94 acura integra LS that came standard with 14" steelies. I use to run Azenis on the old steelies, then switched them over to 14x6 bmw bottlecaps. Should I up grade to 15x6.-15x7 range with 205 azenis? The response on track seems okay with the 14x6, but wondering If going with 15" wheels make a difference?
Old Aug 15, 2008 | 08:01 AM
VTECIntegra9's Avatar
Ive been on 15x7 with 205 azenis for a long time now and think the wheel size to tire size works very good. 6"wide is a pretty skinny wheel IMO
Old Aug 15, 2008 | 08:39 AM
unrealwrc's Avatar
Default Re: Wheel Size (Gong Show)
yes the 205 will make a BIG difference. I recommend the 15x7 or 15x7.5 if you can get it. you'll need it with the new beast thats going in there
but if you ever wanted to upgrade brake size then I would recomend jumping higher then 15. but for auto-x, and occasional track days it will be great.
Old Aug 15, 2008 | 01:21 PM
The Destroyer's Avatar
Default Re: Wheel Size (unrealwrc)
Im looking to step it up to 16x7 w/ 225's when my current tires are done.
Old Aug 15, 2008 | 02:06 PM
Lo-Buck EF's Avatar
15x7 +38 and your set. plenty of room for growth in tire width and as large a brake set up as you'll need.
any particular reason you want to go 16s?
Old Aug 15, 2008 | 02:28 PM
Default Re: (Lo-Buck EF)
To fit a good 225 street tire. Unless some of the good street tires start making them wider for 15's. (z1, Re01, re11, or some of the others coming out). Im not sure if I need a 225 but id like to try it.
Old Aug 16, 2008 | 09:27 PM
Lo-Buck EF's Avatar
Default Re: (The Destroyer)
aah. good plan.
Old Aug 18, 2008 | 04:43 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Destroyer &raquo;</TD></TR><TR><TD CLASS="quote">To fit a good 225 street tire. Unless some of the good street tires start making them wider for 15's. (z1, Re01, re11, or some of the others coming out). Im not sure if I need a 225 but id like to try it. </TD></TR></TABLE>
Assuming you are also in an Integra. You know you will have to run at least -3 camber and have a slight fender roll to accomodate that tire size up front. I compromised and went with 215's to eliminate all the extra hassle. It did limit my chioces in tire selection though.
Old Aug 18, 2008 | 05:59 PM
Default Re: (get RIGHT)
No, im in a civic. The ride height plays a role in fender clearance no?
Old Aug 18, 2008 | 06:40 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Destroyer &raquo;</TD></TR><TR><TD CLASS="quote">No, im in a civic. The ride height plays a role in fender clearance no? </TD></TR></TABLE>
I remembered after I posted. Indeed.
Old Sep 10, 2008 | 03:17 AM
b18_spoon's Avatar
What chassis is it?
Moody Inc.
Jun 22, 2018 11:12 AM
ej0513
Jan 18, 2009 07:10 AM
OldMajor
Jan 14, 2009 02:18 PM
dc-lefty
May 8, 2006 07:59 PM
bleek
Feb 16, 2005 10:50 PM
