help me out here
Old Aug 14, 2008 | 10:34 PM
kaspa35's Avatar
Default help me out here
I changed my intake mani from stock to a sk2.....then when i would turn the key forward and let the fuel pump kick on the injectors spit gas from the top (by the fuel rail)...and i was told that it was the top o-rings...so i orderd 4 new ones from the dealership....so can any one confirm my diagnoses on the prob....and also what would be the easiet way to put them on?
Old Aug 15, 2008 | 06:38 AM
AWD Terror's Avatar
Default Re: help me out here (kaspa35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaspa35 &raquo;</TD></TR><TR><TD CLASS="quote"> the injectors spit gas from the top by the fuel rail</TD></TR></TABLE>
Well if fuel is leaking from the top of the injectors, one could come to the conclusion that the top o-ring is leaking.
Old Aug 15, 2008 | 06:46 AM
LSracing94's Avatar
Default Re: help me out here (AWD Terror)
o-rings are shot
Old Aug 15, 2008 | 08:12 PM
reflexgsr-t's Avatar
Default Re: help me out here (LSracing94)
I had the same problem. Use white Lithiu dontm Grease to lube up the o-rings if you use it you could f up the o-rings your fuel rail should almost make a click sound dont force it you will know good luck
Old Aug 16, 2008 | 08:29 PM
kaspa35's Avatar
Default Re: help me out here (reflexgsr-t)
yea thanks guys....i got them in all good no more leaks!! ....now the ....i havent tried to start the car for prolly 2 weeks....and last time i did it started fine....even when i first noticed the oring leak the car turned over normal...but now when i try to start it there is a schreaching (sp?) sound and the car wont start just crank...its coming from the right side of the block...in the alternator area...any hellp would be great guys...if needed i could get a vid of it...but let me know...
some more info on the car...
1990 DA9....bolt ons....i/e/sk im......
Old Aug 16, 2008 | 09:06 PM
superfast666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaspa35 &raquo;</TD></TR><TR><TD CLASS="quote"> I changed my intake mani from stock to a sk2.....then when i would turn the key forward and let the fuel pump kick on the injectors spit gas from the top (by the fuel rail)...and i was told that it was the top o-rings...so i orderd 4 new ones from the dealership....so can any one confirm my diagnoses on the prob....and also what would be the easiet way to put them on?</TD></TR></TABLE>
you probly [freak]ed them up your self installing the new intake manifold
Old Aug 17, 2008 | 08:24 AM
kaspa35's Avatar
Default Re: help me out here (superfast666)
yea most likely....but the leak is all good now...now i just need some guidence on what the sound could be
Old Aug 17, 2008 | 10:14 AM
the alternator belt is too tight
Old Aug 17, 2008 | 11:41 AM
kaspa35's Avatar
how would it have gotten to tight? from sitting? and how could i see if its to tight?
Old Aug 17, 2008 | 11:49 AM
the belt gets old and dry
Old Aug 17, 2008 | 12:24 PM
kaspa35's Avatar
so what can i do to find out if its the belt? i dont want to change it and still have the problem....plus cash is tight....so i want to make sure thats whats causing the noise...thanks guys
Old Aug 17, 2008 | 01:11 PM
kaspa35's Avatar
bump
Old Aug 17, 2008 | 02:54 PM
kaspa35's Avatar
anyone?
Old Aug 17, 2008 | 03:18 PM
take it off and start it it will run on the battery alone for a lttle
Old Aug 18, 2008 | 08:31 AM
kaspa35's Avatar
so i hooked up some jumper cables to it...jumped it and it started screeching went away after about 3 secs of screeching....so the car is idleing sounds kind of rough...then the check engine light comes on and the rpms shoot up to 3k and stay there....then i saw smoke coming from the engine bay so i shut it off right away...coolant was leaking from some where when i looked under the car...but didnt leak until i started it? any ideas...thanks all
Old Aug 18, 2008 | 08:42 AM
---NON-VTEC---'s Avatar
If ur leaking coolant checks all the line then check ur radiator.
Old Aug 18, 2008 | 10:13 AM
cetcivic's Avatar
no one wants to hear the truth
Default Re: help me out here (---NON-VTEC---)
COOLANT LEAK? CHECK THE LINES UNDER THE INTAKE MANIFOLD..3K RPM? CHECK ALL YOUR VACUUM LINES...WHITE SMOKE FROM THE EXHAUST? HEAD GASKET..BUT LET THE CAR GET TO OPERATING TEMP BEFORE U JUMP TO ANY CONCLUSIONS..GOOD LUCK
Old Aug 18, 2008 | 11:50 AM
kaspa35's Avatar
and would a coolant leak be the reason for the rpm spike and the check engine light?
hondacrx2
Apr 23, 2007 06:13 PM
the king.
Sep 25, 2006 05:16 PM
locoSIR20
Feb 9, 2005 04:09 PM
jaydm ferio
12
Jan 20, 2005 11:47 PM
baonest
Aug 5, 2001 02:51 PM
