compression test
Old Aug 14, 2008 | 09:14 PM
92vxjdm's Avatar
Default compression test
alright did the search but only came up in results...
when i did my compression test it would go up 270-275 across the board but it wouldnt stay like it would peak then drops down slowly. is this mean i got a leak some where or is this the way it works?
Old Aug 15, 2008 | 05:05 AM
turbodcxbro's Avatar
Default Re: compression test (92vxjdm)
is this a compression test or leakdown?
The compression tester should hold the peak pressure obtained in a cylinder until you release it. If not then the gage is bad.
76 camaro car
Apr 20, 2017 04:47 AM
crazyhouse2011
Mar 18, 2013 07:50 PM
F120man
Oct 20, 2002 03:30 PM
