Wont Rev Out
Old Aug 14, 2008 | 08:30 PM
toolbox21's Avatar
Default Wont Rev Out
My Friends Got A D15B7 In His Hatch With A PM6 ECU, And It Wont Rev Out It Revs To 6850 All Day. Its In Time And Temperature Sensor Works Any Idea In What May Be The Problem??
Old Aug 15, 2008 | 06:22 AM
Mr.Death's Avatar
Default Re: Wont Rev Out (toolbox21)
Why caps on every word??? Also your question makes no sense. Try again....
Old Aug 15, 2008 | 07:30 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
^^^use it, then repost.
Old Aug 15, 2008 | 10:28 AM
sinepome's Avatar
do you mean it just stays on 6800rpm.? try re-wording your question.
Old Aug 15, 2008 | 10:36 AM
ef-hatchcrap's Avatar
Default Re: Wont Rev Out (sinepome)
What he means is that a pm6 ecu has 3 rev limiters cold 6850, semi warm 7000, an fully warme up the limiter is 7500.
What he is trying to explain is that he cant hit the 7500rpm rev limiter it always stops him at 6800 rpms
Old Aug 15, 2008 | 12:00 PM
Hovey's Avatar
Default Re: Wont Rev Out (ef-hatchcrap)
why would you want to push your car to redline.....there is no point
Old Aug 15, 2008 | 12:16 PM
CRX_RR's Avatar
go buy a rev limit chip
Old Aug 15, 2008 | 04:46 PM
toolbox21's Avatar
Default Re: Wont Rev Out (CRX_RR)
[stop flaming people]
Modified by George Knighton at 7:16 AM 10/22/2008
Old Aug 15, 2008 | 05:14 PM
CRX_RR's Avatar
toad where you at
Old Aug 15, 2008 | 06:25 PM
zccr-xsi's Avatar
lol!
sounds like it aint going past cold rev limit for some reson,my dohc zc wont heat all the way up and it wont go past cold revs,i just rasied the cold rev limit to macth the hot limit problem solved.
Old Aug 17, 2008 | 07:21 PM
kaddi88's Avatar
Default Re: Wont Rev Out (zccr-xsi)
How would a person do that? and what do u need to do it?
Old Aug 17, 2008 | 07:30 PM
guy_from_nerk's Avatar
Default Re: Wont Rev Out (kaddi88)
People and their damn redlines, you do realize that your prob not making power above 6800 rpms anyways with a stock cam thus no real reason to rev to the moon other then to float a valve eventually and sound "cool"
Old Aug 18, 2008 | 08:47 AM
ComeOnKip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolbox21 &raquo;</TD></TR><TR><TD CLASS="quote">For HOVEY:
Dude first of all dude your a dumb ***, evidently you dont know ****, i think you think you clicked the wrong link, i think you wanted SCION-TECH!!</TD></TR></TABLE>
I hope you drive your car at redline into the ocean. Each time you open your mouth its getting much more obvious that YOU know nothing about cars. STFU and GTFO. Please take any fail you might have dropped with you. ********.
Old Aug 18, 2008 | 09:48 AM
Hovey's Avatar
Default Re: Wont Rev Out (ComeOnKip)
you dont make power past 6800 rpm. so what is the point to taking it past that. if the motor was built with the proper valve, spring. ret, and had a cam i could understand pushing a bit more with your rpm but on a stock motor? so go ahead and make fun of me all you want i dont really care....your not gunna hurt my feelings lol
Old Aug 18, 2008 | 05:05 PM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaddi88 &raquo;</TD></TR><TR><TD CLASS="quote">How would a person do that? and what do u need to do it?</TD></TR></TABLE>
u need a chip ecu and in the bin u got a hot and cold rev limit.you need to go in the rom and reset the cold rev limit same as the hot one.the cold rev limit is there so on a cold start u dont overev the motor and low out the headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guy_from_nerk &raquo;</TD></TR><TR><TD CLASS="quote">People and their damn redlines, you do realize that your prob not making power above 6800 rpms anyways with a stock cam thus no real reason to rev to the moon other then to float a valve eventually and sound "cool"</TD></TR></TABLE>
WRONG AND RIGHT
the resaon people rev past the rpm where there power stops is because when u shift at 6800 your rpms will drop to low then if your shifting at 7400.but on the other hand u are right anything past 6800 rpms you dont do nuttin but rev it out.andi agree if u over rev the motor it will see vlave float at like 8k on stock valvetrain.
Old Oct 21, 2008 | 08:47 PM
turdslow's Avatar
hate to say this but if my car woudlnt do something it was designed to do from the factory id consider it a problem, hindering performance potential of the engine/car.
just cause it doesnt make power past 6800 doesnt mean its ok for something not to function the way it was designed to operate. You all need to focus on the core of his problem and not your opinions that have nothing to do with his needs.
MY suggestion is check the harness maybe the harness has poor connection form the temp sensor and the voltage drop is too large so the computers not getting a proper voltage reading. also check your thermostat possibly its opening too soon and the cars not reaching proper temperature.
Old Oct 22, 2008 | 02:55 AM
~sp33~'s Avatar
EFB055
Oh my god, grow up.
Old Oct 22, 2008 | 05:48 AM
89Turbo_Angel's Avatar
Default Re: Wont Rev Out (~sp33~)
Why do you guys even bother replying to this dumb@ss??
Modified by 89Turbo_Angel at 6:55 AM 10/22/2008
Old Oct 22, 2008 | 05:50 AM
ComeOnKip's Avatar
Default Re: Wont Rev Out (89Turbo_Angel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89Turbo_Angel &raquo;</TD></TR><TR><TD CLASS="quote">Why do you guys even bother replying to this dumb@***??</TD></TR></TABLE>
'cause it's fun to make fun of morons? *shrug*
Old Oct 22, 2008 | 07:29 AM
kojack_0's Avatar
well he is using an obd0 ecu on an obd1 motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">the resaon people rev past the rpm where there power stops is because when u shift at 6800 your rpms will drop to low then if your shifting at 7400.but on the other hand u are right anything past 6800 rpms you dont do nuttin but rev it out.andi agree if u over rev the motor it will see vlave float at like 8k on stock valvetrain.</TD></TR></TABLE>
agreed.
Old Oct 23, 2008 | 04:04 AM
Default Re: Wont Rev Out (kojack_0)
Have you checked your windshield wiper fluid? You might need a new tranny AND new hubcaps. Good luck.
Old Oct 23, 2008 | 12:52 PM
jooky5's Avatar
some cars must only come with 1st gear?
severaltony
Mar 15, 2012 11:23 PM
KpaTyH
10
Feb 28, 2010 01:52 PM
black0hatch
Jan 18, 2008 09:20 AM
eknine
Jul 18, 2003 08:06 PM
