Yet another question on the HAsport EFB2 kit..
I finally replaced the driver side mount bracket.. One hole is threaded, while the other one is not. I assume the non-threaded hole requires a stud/locking nut. The kit provided enough locking nuts, [four, actually] but I'm not sure which stud to use. The two studs on the old mount bracket look too small to fit in the hole, but I haven't actually taken them out to see yet.
Thanks in advance..
Without you guys I'd be lost-
Thanks in advance..
the threaded hole on the new block bracket is for a stud from a 90-93 integra or 88-91 civic/crx
the other hole will use a bolt and lock nut
the 2 studs on the old mount bracket you just leave on the bracket
flanker
Dec 8, 2014 01:26 AM
BoostedEgHatchFl
Aug 14, 2008 07:29 PM
XkjeldorX
Jun 21, 2006 01:49 PM
