Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
suggestions on launch from the hole...
Old Aug 14, 2008 | 05:32 PM
i-VtecdaviK2oz3's Avatar
Default suggestions on launch from the hole...
what rpm is best for a 06 civic si to take off from the line?
Old Aug 14, 2008 | 05:39 PM
MessGSR's Avatar
Default Re: suggestions on launch from the hole... (i-VtecdaviK2oz3)
i FEATHER from 4500, but the si is NOT built for drag racing. AUTO X, you will never go back to drag racing
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VtecdaviK2oz3 &raquo;</TD></TR><TR><TD CLASS="quote">what rpm is best for a 06 civic si to take off from the line?</TD></TR></TABLE>
1-1.5K. That's the best for the car.
Unless you're trying to race....which is what it sounds like. In that case it just depends on the conditions. Good tracks usually have alot of grip on the surface which means you should probably launch around 4.5K and feather the throttle to avoid excessive wheel-hop. But of course not all tracks are the same and you just have to adapt to the different surfaces.
On surface streets it's a different story. If the street isn't "grippy" enough or your tires are crap you could launch from 2K rpms mash the throttle and light up the tires all the way to redline.
It all just depends on the road surface. There's no set RPM that works on all surfaces. Best bet....launch at a midway point and if you feel the tires breaking loose excessively....back off the throttle until you get some grip and then go to town.
civic_jdm09
Apr 13, 2010 11:10 AM
b16bri
Jan 28, 2008 01:49 PM
fastlimegreencivic
Feb 21, 2006 03:06 PM
Arturbo
Sep 21, 2003 11:07 PM
R THIS
Jul 31, 2003 10:01 AM
