Socketed hondata p28 ecu and map sensor code on two different cars, Whats up?
I socketed a p28 ecu and installed hondata s300 all by the book and socket tested good. The p28 was a good running ecu from the b18c car that after socketing I get the map code. I socketed the ecu and hondata socket tester tested it and it is good. The other chip was already installed from the vtec/b18 mod. I soldered in the datalog pins and cut the j1. On two different cars one obd0 b16 converted to obd1 for hondata and a obd1 b18 I get a map sensor error on hondata and the sensor sits at 10.7psi.
What should I be looking for beside wiring on the cars? I am 99% positive it has something to do with the ecu but I don't know what I should be looking at in the ecu (map sensor circuits)?
I tryed hondata on a few different stock hondata supplied maps and nothing changed helped.
Let me know what you guys think! Thanks!!
jorge3036
Engine Management and Tuning
Feb 11, 2016 04:06 PM
snowseeker
Aug 29, 2008 07:49 AM
