Suspension & Brakes Theory, alignment, spring rates....
someone help im rubbing bad
Old Aug 13, 2008 | 09:39 PM
thebleek's Avatar
Default someone help im rubbing bad
i put some 205/40-17's on my 97 civic dx. everytime i hit a dip in the road i rub. i have adapters on the car which covert a 4x100 to a 4x114.3 its just a 1'' and doesnt really make a dif in my opinion.
so what can i do? should i order different tires for it?
Old Aug 14, 2008 | 07:13 AM
Targa250R's Avatar
be professional
Default Re: someone help im rubbing bad (thebleek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek &raquo;</TD></TR><TR><TD CLASS="quote">i put some 205/40-17's on my 97 civic dx. everytime i hit a dip in the road i rub. i have adapters on the car which covert a 4x100 to a 4x114.3 its just a 1'' and doesnt really make a dif in my opinion.
so what can i do? should i order different tires for it?</TD></TR></TABLE>
You haven't mentioned wheel width or offset. Whatever the wheel offset is, you're effectively decreasing it by 25mm with the hub adapters. While your (incorrect) opinion is that it doesn't make a difference, the fact is that it makes a huge difference.
Changing tires will not improve your situation. You're going to need to buy wheels that actually fit your car. Otherwise, your only options are to modify the body for fender flares, or stop the suspension from moving.
Old Aug 14, 2008 | 11:01 AM
Tyson's Avatar
so you spaced the wheel 1" and youre wondering why its rubbing?
it IS a big deal.
your choices are obvious.
Old Aug 14, 2008 | 01:08 PM
thebleek's Avatar
Default Re: someone help im rubbing bad (Tyson)
ok well how do i fix all this?
i dont know the offset, they were wheels from an accord that were 4X114.3
cant i just roll my fender more underneath my car? its only the rear tires that are rubbing, the fronts are perfect
Old Aug 14, 2008 | 02:01 PM
Tyson's Avatar
dont try to use wheels that dont fit.
Old Aug 14, 2008 | 11:29 PM
thebleek's Avatar
my wheel is 17x7
Old Aug 14, 2008 | 11:34 PM
Tyson's Avatar
even worse.
Old Aug 15, 2008 | 11:16 AM
thebleek's Avatar
if your not going to help, then shut the f=== up
Old Aug 15, 2008 | 12:12 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek &raquo;</TD></TR><TR><TD CLASS="quote">if your not going to help, then shut the f=== up</TD></TR></TABLE>
chill bro, you came here for help so just soak it all in and listen.
Any 92-00 civic and/or 90--01 integra should not be running anything bigger than 16inch rims. Anything bigger than that will throw off your mpg. I'm assuming you have a semi stock dx which isn't pushing much hp. With a smaller rim/tire combo acceleration, handling, and mpg will improve. I'd suggest 15inch rims w/ either 195/50 or 205/50 tires. As for running adpaters, i wouldn't run any adapters at all. Its unsafe!
Old Aug 15, 2008 | 03:11 PM
thebleek's Avatar
Default Re: someone help im rubbing bad (bmoua)
i have a 00 d16y8 motor swapped in with a stage 1 gude cam.
so its not just a stock non vtec motor.
so how the [freak] do i get rid of these? should i sell em on craigslist?
i thought 17's were the biggest you could go. they look really good on the car. i traded a carbon fiber oem hood for them so idk what to do now
Old Aug 15, 2008 | 03:19 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek &raquo;</TD></TR><TR><TD CLASS="quote">i have a 00 d16y8 motor swapped in with a stage 1 gude cam.
i thought 17's were the biggest you could go. they look really good on the car. i traded a carbon fiber oem hood for them so idk what to do now</TD></TR></TABLE>
sell the rims and pick up a set of oem/aftermarket 15inch rims. Trust me, there will be a dramatic change in acceleration, handling, and mpg.
Old Aug 15, 2008 | 04:11 PM
thebleek's Avatar
i dont care really about mpg or acceleration. The really only problem i have is when i encouter a big dip and i have a passenger in the rear seat.
Old Aug 16, 2008 | 08:55 AM
Targa250R's Avatar
be professional
If you don't like the advice, then don't ask for help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek &raquo;</TD></TR><TR><TD CLASS="quote">i thought 17's were the biggest you could go.</TD></TR></TABLE>
17x7s can be used on a Civic, but you need the correct offset, tire size, and suspension setup for it to work out.
Old Aug 16, 2008 | 10:56 AM
thebleek's Avatar
Default Re: someone help im rubbing bad (Targa250R)
****, im down for advice...
but what that person was giving...wasnt.
Old Aug 16, 2008 | 06:28 PM
everythingwentblack's Avatar
sell them rims for some si's!
Tyson's Avatar
good advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">dont try to use wheels that dont fit.</TD></TR></TABLE>
Old Aug 18, 2008 | 09:22 AM
EnjoyTheRideDC2's Avatar
There is no other tire you can run on a 17" wheel that will reduce the sidewall height and eliminate rubbing.
One option is raising your car up a bit.
Another option is buying a wheel with the correct fitment for your car.
You might think 1" is nothing.... but imagine your wheel was pushed in 1" further into your wheelwell. Or better yet, look at the area you're rubbing onto and see what's 1 inch deeper....maybe no rubbing?
Old Aug 19, 2008 | 10:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Any pics of your car in its current setup? I'm interested to see how it looks with these 1" spacers.
I suppose the Accord wheels could be a pretty high offset, but still, with that 25mm reduction it's probably a much lower offset than it should be. You should be running somewhere around a 38-42mm offset with a 7" wide wheel.
Old Aug 19, 2008 | 04:08 PM
beanbag's Avatar
You need to find out what the stock offset is, and what the new offset is. Maybe it is a number that is printed somewhere on the rim. For example, something in the range of 30-50? Maybe you can get your rotors machined down or something? Or buy another set of rotors with a different offset?
Old Aug 19, 2008 | 07:39 PM
Default Re: someone help im rubbing bad (beanbag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanbag &raquo;</TD></TR><TR><TD CLASS="quote">You need to find out what the stock offset is, and what the new offset is. Maybe it is a number that is printed somewhere on the rim. For example, something in the range of 30-50? Maybe you can get your rotors machined down or something? Or buy another set of rotors with a different offset?</TD></TR></TABLE>
Shaving metal off a rotor will reduce the structural integrity of the part and could endanger someone's life. IMO, to resort to something like that just to rock a specific wheel on a car is flat out ignorant.
Regarding rotors and having different hub sizes....I dont think any company manufacturing rotors have them available in optional hub offsets
What i'm now wondering is if there is another company that makes a spacer thats not as thick and will allow him to run his wheels..
Old Aug 19, 2008 | 09:03 PM
jdm602's Avatar
Default Re: someone help im rubbing bad (EnjoyTheRideDC2)
all about the offset. most lowered cars cant even run a +10 offset. also to consider the width of the tire. and the fact that its a 17x7 wheel is somthing to think about too. larger the diameter of the wheel, the closer it will come to the fender, especially turning. thats why oem is 6" wide.
Old Aug 20, 2008 | 02:51 AM
beanbag's Avatar
OK, i just saw that the back side of the wheel mounting surface on honda rotors is hollowed out, so machining down this surface would be a bad idea. Never mind, then
Old Aug 20, 2008 | 12:34 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">What i'm now wondering is if there is another company that makes a spacer thats not as thick and will allow him to run his wheels.. </TD></TR></TABLE>
He's not using a spacer; he's using a hub adapter to convert the bolt pattern from 4x100mm to 4x114.3mm. There really is no way to make a hub adapter that uses up less space. His only option other than using different wheels would be to install a '96-97 JDM ITR brake/hub conversion, which has many downsides (including expense and parts availability) and is rather silly to do just to run a specific set of wheels.
Old Aug 20, 2008 | 02:51 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
He's not using a spacer; he's using a hub adapter to convert the bolt pattern from 4x100mm to 4x114.3mm. There really is no way to make a hub adapter that uses up less space. His only option other than using different wheels would be to install a '96-97 JDM ITR brake/hub conversion, which has many downsides (including expense and parts availability) and is rather silly to do just to run a specific set of wheels. </TD></TR></TABLE>
yeah, no doubt a heavy@$$ set of wheels at that. 17x7 stock Honda wheels probably weigh 22-25 lbs. Euro Accord 17x7 wheels were 21.8 lbs according to wheelweights.net, so most likely those USDM Accord wheels are even heavier.
Old Aug 21, 2008 | 01:59 AM
thebleek's Avatar
yeah its an adapter, because why the hell would i want a spacer lol.
what about some tighter springs? i only scrape in the rear every once and a while on dips.
