Turbo exhaust housing repair
Old Aug 13, 2008 | 07:02 PM
95delsolz6's Avatar
Default Turbo exhaust housing repair
I have garrett t3/t4 that needs the exhaust housing welded. My question for everyone is about the preheating procedures. My plan was to used some 7018 or er70s tig rod, but I don't know about the preheat. All I need to do is fill in the 1/8" hole in the picture. I've heard cast needs to be preheated to like 350, if this is the case can I place it in the oven for an hour and then weld it?
Old Aug 13, 2008 | 08:00 PM
maximumjohnson420's Avatar
yep cast needs to be heated to like 350-400 degrees before being welded
Old Aug 14, 2008 | 01:46 PM
TigWiz's Avatar
Default Re: (maximumjohnson420)
if you ever plan to make anthing in your over to eat evr again I wouldn't recomend using your oven. Though an oven is the perfect tool for the job.
Old Aug 14, 2008 | 01:53 PM
k24em2's Avatar
Default Re: Turbo exhaust housing repair (95delsolz6)
Try a grille
Old Aug 14, 2008 | 05:57 PM
95delsolz6's Avatar
Default Re: Turbo exhaust housing repair (k24em2)
Good call on the grille. That means I really need to go get the propane tank filled, because now it's a neccessity. Thanks for the information.
Old Aug 15, 2008 | 11:27 AM
Top Ramen's Avatar
Yes - it is much, much easier to weld if you preheat it.
I have a cheap-@ss $20 used oven that I use for everything from pre-heating cast stuff for welding to powder coating. Its on casters and has a table top on it, so it really doesn't get in the way at all. I push it out and plug it in when I need it.
I have also used those IR heaters that sit on top of a propane tank. Just hang whatever you are heating from a metal wire and check it with a laser thermometer.
Best of luck with your project.
95GSRTT
Mar 31, 2007 11:03 PM
Metal Head
Jul 11, 2006 02:38 PM
O16581724 5 2 5
Dec 17, 2005 06:41 AM
TheIntegraGuy
Aug 9, 2005 11:00 AM
