over heating problem ?
Old Aug 13, 2008 | 06:09 PM
eggsi619's Avatar
Default over heating problem ?
hey guys im new here so cut me some slack. my car tends to over heat and i notice that coolant fills up in the resivior and starts to over heat. I recently flushed my motor and replaced a new thermostate and still the problem continues. should i replace the head gasket as well or what? please help! thank you guys.
Old Aug 13, 2008 | 06:31 PM
taztwnpa's Avatar
Default Re: over heating problem ? (eggsi619)
did you bleed the system? remove rad cap and start engine and wait untill fan comes on. loosen the bleeder and let fluid come out untill there is no air bubbles. Make sure rad is filled and put cap on.
Old Aug 13, 2008 | 07:24 PM
EKstacy's Avatar
Default Re: over heating problem ? (taztwnpa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taztwnpa &raquo;</TD></TR><TR><TD CLASS="quote">did you bleed the system? remove rad cap and start engine and wait untill fan comes on. loosen the bleeder and let fluid come out untill there is no air bubbles. Make sure rad is filled and put cap on. </TD></TR></TABLE>
yea, definantly bleed it and report back.
JDM_SOHC
34
Jun 23, 2009 02:52 AM
CarbonfiberR
Nov 7, 2008 10:02 AM
tmurda253
13
Nov 4, 2008 08:53 PM
Type-r-driver-2000
Sep 22, 2007 07:24 AM
blackpearlv6
Jun 8, 2006 11:04 AM
