Suspension & Brakes Theory, alignment, spring rates....
Camber Kit
Old Aug 13, 2008 | 02:13 PM
91civicsikid's Avatar
Default Camber Kit
I just bought the eibach prokit for my 91 civic si and have been looking at camber kits. I'm not really sure what to look for but I know I want a kit that works well for under 100. Any suggestions?
Old Aug 13, 2008 | 02:16 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Camber Kit (91civicsikid)
buy one used if ur shootin fo unda 100.
refer to this
https://honda-tech.com/zerothread/2358865
Old Aug 13, 2008 | 08:02 PM
skynyrd006's Avatar
Default Re: Camber Kit (Egezzy)
I think that camber kits are waste of money imo. If uneven tire wear is the reason for you wanting one, toe is your problem, not camber. However, if you really want to get one, dont go cheap. Get skunk2, ingalls, etc...
Old Aug 15, 2008 | 02:13 AM
i was planning on getting some eibach springs and lowering maybe a couple inches or so... how do you fix toe?
Old Aug 15, 2008 | 07:41 AM
skynyrd006's Avatar
Default Re: (91civicsikid)
An alignment shop will adjust your toe. Be sure and get them to set it to zero.
Alot of shops(at least in my area)wont set the toe to zero and they will tell you to get a camber kit because neg camber and zero toe isnt in factory spec. They dont realize that when a car is lowered, the factory specs no longer apply.
Usually a repuatable shop wont give you any problems.
Old Aug 17, 2008 | 06:48 AM
Default Re: (skynyrd006)
Cool. I'll look into it.
Old Aug 17, 2008 | 08:24 AM
Egezzy's Avatar
Default Re: Camber Kit (skynyrd006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skynyrd006 &raquo;</TD></TR><TR><TD CLASS="quote">I think that camber kits are waste of money imo. If uneven tire wear is the reason for you wanting one, toe is your problem, not camber. However, if you really want to get one, dont go cheap. Get skunk2, ingalls, etc...</TD></TR></TABLE>
thank u!! finally a non ignorant ******* on this subject!!!! to u my friend.
Old Aug 18, 2008 | 09:29 PM
jdm602's Avatar
yea just adjusting the toe is good enough. zeroing that will improve tread wear a lot.
and ive heard some stories of camber kits tearing shock towers on lowered cars.
Old Aug 19, 2008 | 07:19 AM
skynyrd006's Avatar
Default Re: Camber Kit (jdm602)
Also, if you are slammed, a camber kit will reduce what little suspension travel you have. They are bigger than the oem upper control arms and are more likely to hit the fender well.
Old Aug 19, 2008 | 08:31 AM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skynyrd006 &raquo;</TD></TR><TR><TD CLASS="quote">Also, if you are slammed, a camber kit will reduce what little suspension travel you have. They are bigger than the oem upper control arms and are more likely to hit the fender well.</TD></TR></TABLE>
This is FACT. There's many people out there who "dump" their rides... tell them to show you pictures of their shock towers. haha I garantee you if they don't have a refabbed tower, there's pretty good indentations or holes there for your viewing pleasure.
Old Aug 19, 2008 | 09:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
heh my car has been lowered for 6 years, and I don't have so much as a dent in my shock towers. I attribute that to never having any sort of camber kit.
Camber correction is 100% NOT needed with ProKit springs.
Old Aug 19, 2008 | 09:42 AM
AlphaQup's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">heh my car has been lowered for 6 years, and I don't have so much as a dent in my shock towers. I attribute that to never having any sort of camber kit.
Key plus you can still make U turns, without any rubbage with your ride height.
Old Aug 19, 2008 | 01:01 PM
Targa250R's Avatar
be professional
You will not need a camber adjuster kit with Eibach Pro Kit springs.
To eliminate uneven tire wear, you will need to have the car aligned to set the toe after the springs are installed and the bushings are reset. Make sure all ball joints and bushings are tight and free of play before the car is aligned.
If you find that you need additional negative camber for handling and balance purposes, the only off-the-shelf camber adjuster kit you should buy for an '88-91 Civic is the Skunk2 Pro Series. Nothing else is worth buying. Yes, it's more than $100 (it's $253 and currently backordered), but I guarantee that you will have problems with anything else.
91EF919
Jun 30, 2009 04:11 PM
noz
Suspension & Brakes
Feb 18, 2009 07:53 PM
doubleshotz
Suspension & Brakes
Nov 2, 2007 05:01 PM
crx1009
Apr 5, 2006 09:57 AM
Anderson
Jun 18, 2002 01:06 PM
