2 problems on '93 Si(obd-1 jdm h22a swap)
I'm in the final phase of getting the car on the road, and ran in to two problems. The first problem didn't seem to ever show itself until I installed a chipped/converted p06 + xenocron tune. The second problem has been around since I got the car, no idea when it started happening.
First problem; When shifting at higher rpms, the car will occasionally "buck" really hard. It seriously causes me to lunge back and forth in my seat when it happens. If I let off the throttle, the problem stops. I can only get it to do this when shifting at higher rpms at full throttle. If I had to guess, it sounds like the clutch...but why did it only show up recently? Just coincidence? If it is the clutch...what exactly could be wrong with it?
Second problem; Odometer and tripmeter do not work at all. I bought the car with a blown motor and ever since the swap I never noticed the miles change on either display. Tachometer and speedometer work great. Those could have been faulty before I even got the car, as far as I know.
Car info = '93 Si, jdm h22a/usdm h23a harness/jdm h22a distributor(fuse mod)/usdm h23a fuel rail/usdm h23a front coolant housing/rywire vtec sub-harness, usdm p06(converted/chipped/xenocron tune), civic radiator, 12" slim fan, usdm h23a 5spd trans, i/h/e.
VXvtec
May 28, 2022 07:55 PM
Ntense90crxsi
Feb 13, 2006 10:03 AM
