gsr wiring help?
Old Aug 13, 2008 | 11:39 AM
757toad's Avatar
Default gsr wiring help?
ok... i have a 90 si hatch with a b18b1 obd0. i bought a obd2 gsr comlpete swap to put in my hatch. i have an obd1 chiped ecu from phearable.net and the obdo to obd1 harness. i was told i need to put the obd0 hanress and the obd2 harness together to make the motor run in the car but they never told me what or how to do this can any one help me with my problem?????
thanks.
Old Aug 13, 2008 | 01:13 PM
Ldo's Avatar
Ldo
Default Re: gsr wiring help? (757toad)
Just get the distributor and injectors for OBD1 GSR and use your OBD0-OBD1 jumper harness.
Old Aug 14, 2008 | 03:24 AM
757toad's Avatar
Default Re: gsr wiring help? (Ldo)
that sounds alot easier than i thought. i had some one else tell me to
"convert it to obd2 at the alternator, distributor & injector plugs on the engine harness."
thats why im so confused about it. i know its not to hard of a swap i just need to figure out how the wiring should be done. getting an obd1 distributer and injector sound pretty easy. anything else i need to do?
thanks for your help!!
zsoccerdude17
Mar 10, 2010 06:42 PM
gotboosthatch
Feb 16, 2008 03:44 PM
drshottest718
Apr 19, 2006 10:42 AM
alucardex
Aug 19, 2005 11:32 AM
civicsirplus
Aug 10, 2003 05:04 AM
