Do you have this solenoid valve on your sock?
Old Aug 13, 2008 | 09:21 AM
sEa lOS gRill's Avatar
Default Do you have this solenoid valve on your sock?
I need a some help from you guys my IAB has been inop for a bit so i decided to check it out. Well I found the vacuum solenoid valve had no continuity and is not feeding the IAB diaphragm any vacuum so it was always stuck open.
So I know my local junk yard has a bunch of 5th gen civic's and wondering if you any of you guys know or can look if you have a solenoid valve that looks like this on your car if you have a SOHC. Thanks.
thats the IAB vacuum tank with solenoid valve
thats the EVAP canister solenoid valve I think I can use that one.
thats the connector
I have a 95 ex with a gsr. Oh and sorry for the crazy size phone pix its all i have.
Old Aug 26, 2008 | 10:21 AM
Default Re: Do you have this solenoid valve on your sock? (sEa lOS gRill)
I went yesterday to my local junk yard and pick up a Evap solenoid valve off an LS Tegie for a couple bucks, and installed it on my IAB vacuum tank. Works again. When I looked around I found the 5th gen civics had the same solenoid valve for the EVAP canister. Thanks for for looking out H-T!
airikkCRX
May 18, 2007 09:51 PM
MadVtak
Oct 19, 2006 02:39 PM
vtec.dc2
Oct 15, 2006 10:19 AM
Cyber ITR
Nov 21, 2004 06:26 PM
Evil DOHC
Sep 24, 2001 04:36 PM
