BB turbo's....any others then the GT's?....
Old Jul 22, 2002 | 10:58 PM
*Boostwerks*'s Avatar
Default BB turbo's....any others then the GT's?....
Looking for the best + most INexpensive BB turbos available.
any info....links would be GREAT!!
Thank's
Bryson
Old Jul 22, 2002 | 11:47 PM
VaporTrail's Avatar
New User
Default Re: BB turbo's....any others then the GT's?.... (Bryson)
cheapest ones i know of are the Turbonetics ones, and they arent cheap either (bout 1100).
Old Jul 23, 2002 | 05:50 AM
kidkutz's Avatar
Default Re: BB turbo's....any others then the GT's?.... (VaporTrail)
yup turbonetics are the cheapest bb turbos. some actually don't consider turbonetics' ceramic bb as being a TRUE bb....but they work ok.
Old Jul 23, 2002 | 06:22 AM
leadtrum's Avatar
IHI makes tyte *** ones...they're used by apexi and for subaru's I believe.
Old Jul 23, 2002 | 08:55 AM
SiRkid's Avatar
Default Re: BB turbo's....any others then the GT's?.... (leadtrum)
HKS
but i dont think you wanna be dishing out lke 4500 US for a turbo
Old Jul 23, 2002 | 09:54 AM
Sonny's Avatar
JDM Garrett T28, but you knew that already. If the one from the S15 Silvia is too small for you, the Pulsar GTiR one uses a larger turbine housing.
Sonny
Old Jul 23, 2002 | 02:40 PM
Default Re: BB turbo's....any others then the GT's?.... (Sonny)
You have any pictures of that turbo?
That turbo seems like it would be a great option, but I don't want to pick it and have no idea what it looks like.
.......can't beleive I'm asking this AGAIN!!!........but what is the HP potential for this turbo?
Thank's Sonny
Old Jul 23, 2002 | 03:06 PM
Sonny's Avatar
Specs:
.63 A/R Turbine Housing
73 Trim GMR Turbine wheel
Water cooled ball-bearing center section
.60 a/r Garrett T04B compressor housing
60 Trim Compressor Wheel
Louis Anaya (TurbochargedSER) says that the Nissan guys report that they can get about 260whp with this turbo and that it spools by 2500rpm on an SR20. The Pulsar GTiR T28 uses a .86 a/r exhaust turbine and is good for about 300-320whp.
Nobody seems to have much experience with this turbo in the Honda scene, so I guess I'll be one of the first. I'm looking to make about 225 whp, so I think the Silvia T28 will do the job.
I got mine for $495. It was used, but as you can see from the above pics, it is in perfect shape!
Sonny
Old Jul 23, 2002 | 06:03 PM
HXMan's Avatar
Nice pics.
Old Jul 23, 2002 | 08:58 PM
What flange do those turbo's use?
You got that turbo From Anaya right?....I think I might IM him about one of those.
Right now I'm thinking of getting the Pulsar turbo, port/clip/rebuilding it, so it will be able to support a little more power.
What DP housing does that use?....the DSM one wouldn't fit would it?....to me they seem pretty similar.
(THANK'S A TON for those pics!)
Old Jul 23, 2002 | 11:24 PM
Sonny's Avatar
The turbine flange is a T25. I'm going to use an HKS cast iron manifold with mine. I did not buy the turbo from Louis. He didn't have any used ones and the price of a new one was a little out of my reach at the time. I know that he sells the Pulsar GTiR T28 new.
I don't know if the DSM downpipe/discharge flange will fit. I'm not that far yet, man. Ask me in 2 months (hopefully).
Sonny
Old Jul 24, 2002 | 07:51 AM
HYPERTUNE-Mark's Avatar
Here is some pics of my BB turbo (IHI RX6)
BTW, are you SURE the GTi-R turbo is BB?
Late model jap SR20 in the Silvia yes, but RNN14? I don't think so.
[Modified by HYPERTUNE-Mark, 4:53 PM 7/24/2002]
Old Jul 24, 2002 | 09:09 AM
Default Re: BB turbo's....any others then the GT's?.... (HYPERTUNE-Mark)
Yeah just talked with TurboChargedSER....The Pulsar's are NOT BB.
Guess I'm buying a T3/T4 derivitive.
How much are the IHI turbo's?
Old Jul 24, 2002 | 09:21 AM
ArizonaTurbo's Avatar
You an go with a Garrett GT25. It has the same turbine side as the Pulsar GTiR T28, it has a ball bearing center section, and has a T04S compressor housing which can flow 55 lb/min. I can get these turbos as well.
Old Jul 24, 2002 | 11:20 AM
Default Re: BB turbo's....any others then the GT's?.... (TurbochargedSER)
Are these internally gated?
OH BTW, how do you like your TypeR bov? Sound nice?
[Modified by Bryson, 12:24 PM 7/24/2002]
Old Jul 24, 2002 | 11:26 PM
Bumpity
Old Jul 25, 2002 | 02:02 PM
Smashback's Avatar
I'd be interested in pricing for IHI BB turbos also. And I don't suppose they use a T3 compatible flange?
Old Jul 25, 2002 | 02:15 PM
The GT25 does not come with an internal wastegate.
The Type "R" is a necessity if you are planning on producing 400+ whp!
Old Jul 25, 2002 | 08:29 PM
....balanced on the Tial or the TypeR....???...the Tial is just so freaking HUGE!!
[Modified by Bryson, 9:29 PM 7/25/2002]
philbeesperform
Mar 18, 2014 01:00 PM
RACEPAK
Oct 9, 2005 11:14 AM
Pete_SI
Aug 15, 2005 02:55 PM
Bserieskllr
Jul 1, 2005 09:24 AM
LJR-LUDE01
Jul 11, 2002 08:15 AM
