SPfab T*DA B-series and SPfab Tri-Y header ** ceramic coated** in stock!!***
SPfab ( a Subsidiary of SpoolinPerformance's non- turbo products) has brought you a replica of a popular JDM header. Normally, the original header that this design was inspired from has a long leading wait time and carries a 950$ price tag. get your SPfab inspired version today !!!
SPfab T*DA header
- JDM ITR 4-1 bolt on
- direct " JDM" replica
- Merge collectors
- 16 Gauge mild steel
- Ceramic coated
- Ported headflange
- AC compatible
- Keeps fullcore radiator
-will fit DA's and EF's with stock crossmembers
- 2.5 Collector
Price: $550 Shipped $500 Picked up
test vehicle
1999 civic si
custom short ram with blox velocity stack
profab tri-Y smsp copy header
obd I conversion, crome tuned
higher lines -= T*DA header lower lines = profab
keep in mind** this vehicle was tuned for the profab, T*DA header was direct slap on and go ********** also look at the conditions table, T*DA header was ran in 104 heat, Vs 9X degrees***********
SPfab Tri-Y header
-Revised Ground Clearance
- Stepped Header Design 1 3/4 to 1 7/8 to 2 inch to 2.5
- Merge collectors
- Ceramic coated
- Ported headflange
- AC compatible
-will fit DA's and EF's with innovative cross member
- 2.5 Collector
- VERY GOOD RESULTS- Many all motor 200-240 WHP setups proven
- IN STOCK
[I]Price: SOLD OUT[/I]
How to order:
Payment Options:
Paypal---Google Checkout --Money Order/Check/Cashiers Check.
Paypal id: Racerswholesale@gmail.com
call 408.515.4296 for Visa/Mastercard
Mailing Address:
SpoolinPerformance
47000 Warm Springs Blvd, STE 224
Fremont, CA 94539
Local Pick up:
Spoolin/Redzone Performance
43257 Osgood Rd
Fremont, CA 94539
SPfab T*DA header
- Merge collectors
- Ceramic coated
- Ported headflange
- AC compatible
- 2.5 Collector
test vehicle
1999 civic si
SPfab Tri-Y header
- Merge collectors
- Ceramic coated
- Ported headflange
- AC compatible
- 2.5 Collector
- IN STOCK
How to order:
Payment Options:
Mailing Address:
SpoolinPerformance
Fremont, CA 94539
Local Pick up:
43257 Osgood Rd
Fremont, CA 94539
ATS FRED runs our header !
AEM's honda challange race car runs out header- BONE STOCK ITR motor.. made great power on a mustang dyno .. Youtube video seen here
http://www.youtube.com/watch?v=wDjpUG_BVUc
Is the length of the header the same as the JDM ITR header? Meaning, will I need to do any modifications to my 2.5" cat and rsr exhaust to fit this header? I currently want to replace a dented DC JDM 4-1 header.
