best rpm to launch at
Old Aug 13, 2008 | 07:19 AM
bertsb18hatch's Avatar
Default best rpm to launch at
setup is b18a1 bored to 81.50mm, wiescos 11.4:1 pistons,eagle rods,golden eagle blockguard,exospeed stage 3 head, ported and polished, stainless steel valves, supertech valvesprings and retainers, brian crower stage 2 cams, blox intake maniold, blox 68mm throttle body, golden eagle fuel rail, precision 310cc injectors, jdm 4-1 header 2.5 collector, custom length intake with velocity stack,converted to obd1 running on pherable.net basemap, b16 tranny w/ obx lsd. my question is im going to track for the first time with this mottor since i built it, and im gong to be on m&h 8x22x13 slicks w/ lensos. trying to figure out what to launch at. i have only ran drag radials before i built the motor.any ideas on what kinda of times i should put down. with the stock motor on drag radials spinning it went 15.0 constant. 13.5 on nitrous spinning half track.
Old Aug 13, 2008 | 07:31 AM
MR.johnson's Avatar
Default Re: best rpm to launch at (bertsb18hatch)
rev limiter. done.
its called test and tune try it.
Old Aug 13, 2008 | 07:39 AM
Default Re: best rpm to launch at (MR.johnson)
revlimiter is set to 8200
Old Aug 13, 2008 | 09:25 AM
98vtec's Avatar
moderator emeritus
you are going to the track on a basemap?
no one online can tell you where to launch. That takes doing it to find out.
Old Aug 13, 2008 | 11:09 AM
4GE4YA's Avatar
Default Re: best rpm to launch at (98vtec)
Nothing below 7500 on motor! On the bottle, your just gonna have to play with it and see. Some cars when properly setup can hook on the jug out of the hole.
vtec-hurna
Feb 17, 2012 07:16 AM
johnson_racing
Oct 18, 2009 05:02 PM
bertsb18hatch
Sep 1, 2008 02:24 PM
bertsb18hatch
Jun 9, 2008 03:12 PM
HighRevn
31
Dec 9, 2006 06:48 PM
