Differnece between LS/Vtec and B16?
I know what the difference is, but is the LS hybrid really that much better than just a B16 engine? And if so, how much more does the LS/Vtec swap cost compared to just a B16 swap? And who in here actually has a LS/Vtec swap in their 2nd gen Civic or CRX, and if so, any dyno numbers?
b16 = 1.6 L
LS/VTEC = 1.8L
B20 = 2.0 L
That is a big difference.
B16 = reliable power
LS/Vtec = Mickey mousy power
B20 = Reliable tourque
B20 = New motor
B18 = fairly new
B16 = old
B20 = my choice
You can always add a VTEc head to a b20 block a year after your swap
LS/VTEC = 1.8L
B20 = 2.0 L
B20 = New motor
B18 = fairly new
B16 = old
B20 = my choice
b16 a work of art perfect rod stroke ratio lsvtec JUNK very poor RS and teh b20 vtec still junk will have problems like the lsvtec not worth the $$ or the hassle
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
here's a thought, destroked B20.
1.8L, same RS as B16, read revving to 8K+ and still have more torque.
stan
stan
if u destroke a b20 to a 1.8 its just gonna be a b18 ??? but i dont see anywhere near a 1.74 rs not likely....
and teh b20 and b18 dont rev high for a reason RS they are imperfect....ill be one to say it the b16 is a better motor even if there is more torque from the lsvtec its not gonna be reliable anyway u do it....build the bottom end like u say the head is not meant to be bolted on if it was so great hondas engineers that get payed to make **** woulda done it but they didnt why??? because the b18b/a arent meant to have a vtec head thats why u gotta rig a oil line up so it will work....ive seen 4 or 5 lsvtecs 2 built bottom end up and they were still race engines that didnt last forever....and im saysing race engines because u cant rely on that kinda power knowing that u could run into overheating issues oil leakage possibly just not worth it turbo a ****** b16 if u want awsome power or waste a lil money ud be wasting on build the lsvetc and build the b16 for NA it make more than a b18c1 for teh cost that teh lsvtec would cost ive thought this over for about 2 years researched watched friends....b16 is a better motor than the lsvetc or b20 vtec or u could waste the $$ and do a b19c5 cause the $$ ur gona spend is in the neighboorhood of 5 grand on internals ask phattwhippin_crx he has a whole thing on the lsvec on his page it explains the RS for those who dont understand
ls/vtec does not equal mickey mouse power. as stated above, if you take the time to research and find out how to make the b18a rev well enough to make use of the vtec head, and build it right. your problems will be limited. this has been said a thousand times so its simply a matter of opinion.
in the case of which motor is better, you have to ask yourself what you are doing with the car. auto-X, daily driver... i would have to say the b16a is the easiest/most reliable setup. but if you want something to run the quarter, weekend warrior, street terror etc.. you will have to invest a ton of cash to make the b16a a contender. the ls/crv/vtec is a better option, but based on the parts you choose, it can be expensive.
basically a bone stock ls/vtec puts out the same numbers as a bone stock b18c1 (the dyno sheets are on here somewhere) if your willing to chance a bone stock ls/vtec its definitely cheaper than a b18c1, and a lot more powerful than a b16a.
and if you go turbo, then basically get whatever you can for cheap(ls/b16a/etc...) then save the rest of the cash for your turbo setup, and the forged internals you'll require later. hth
i have been in friend's cars with cammed B16's and i have ridden in an LS/Vtec car with b16 pistons, fully balanced bottom end, headwork, CTR cams, all bolt on's, etc. the ls vtec car definitely kicks some ***, i don't think it would pull on the cammed B16. this is due to the CTR cams not being as aggressive as the Crower 2's. my point is that while the ls vtec is fun, it is not a good idea. there are no oil jets in any non vtec block, these are to spray oil onto the wrist pins. with high rpm's, there is a lot of heat and friction involved, and i think the wrist pins are going to be overworked beyond the levels an LS should see. a very bad combination is the hybrid turbo. this will drop oil pressure levels even further and make it more likely to fail! do yourself the favor, buy a VTEC bottom end from the start, preferably a B18C because it makes no sense to buy a C5 if you are reworking it all anyway.
The 1st gen B16 does not have them either
[Modified by ccjb100, 11:51 AM 7/23/2002]
the thing is LS/VTEC was not ment to be nor was CRV-Tec. however the B16 was meant to be. therfore it answers your q's
do either straight b20 swap or b16 swap.
Could there be differences between JDM/EDM spec?
[Modified by ccjb100, 1:13 PM 7/23/2002]
Ok, i'm starting to get an idea of the difference. A B16 is more reliable cause it is from one engine while the LS/Vtec is less reliable cause it's a hybrid.
But what about costs? Are they about the same? I'm guessing they would be.
if you destroke the B20 with the B16 crank, using b16 rods and B20 pistons you will get 1.8L, but it will not be a B18, it will retain the B16 RS and will get it's 1.8L from the 85mm bore. think of it as a OEM massive overbore of a B16.
stan
stan
c0j0nes
11
Jun 5, 2009 07:15 PM
pmptwst17
Mar 2, 2006 05:41 AM
