question on code #43 plz
Old Aug 12, 2008 | 10:41 PM
madmax91efsi's Avatar
Default question on code #43 plz
iv got a 91 civic si that i did a da swap in 91 teg. motor! it makes sence kinda to why im throwing code 43 motor is have cut out problems in high rpms as like its limiting. but could someone kinda brief me more on what fuel supply system code means or what else it relates to plz and thanku??????
Old Aug 13, 2008 | 03:41 AM
rd91sib18c5r's Avatar
Default Re: question on code #43 plz (madmax91efsi)
I had the same swap and the same code change your o2 sensor and it should
go away. good luck
Old Aug 13, 2008 | 02:07 PM
superfast666's Avatar
Default Re: question on code #43 plz (rd91sib18c5r)
also could be gas cap, fpr, fuel pump
Old Aug 13, 2008 | 03:08 PM
thelate1's Avatar
Default Re: question on code #43 plz (superfast666)
i had the same code, turned out to be a loose ground on the thermo housing...
Old Aug 13, 2008 | 10:10 PM
well i think its a starting to go bad fuel pump so im just gonna replace it and go from there
SOHCEK-Turbo
Aug 12, 2022 11:16 AM
mugenteggy001
Jan 31, 2011 07:40 AM
ef9itb
Nov 19, 2007 06:12 PM
jdmrex91
Jul 6, 2004 09:45 AM
