i need help on my stock struts !!! help please !
Old Aug 12, 2008 | 05:59 PM
H0NDAdAddy LS's Avatar
Default i need help on my stock struts !!! help please !
ok so i have this problem, im putting coilover springs on my stock struts & i was wondering if i still needed that sheild that is covering a bolt i need to get too . i know its better off getting new struts but i dont have the money at the moment so im just sticking w. the stock ones & new lowering springs . so, i try to loosen the top bolt so the hole top can just pop off but when i loosen it, the hole strut goes with it . & i tried to loosen another strut but it does the same . so if anybody knows how i can get the stupid old spring off to put my new one, let me know ASAP thnxxxx !
Old Aug 12, 2008 | 08:38 PM
(puma)'s Avatar
Default Re: i need help on my stock struts !!! help please ! (H0NDAdAddy LS)
What you have to do is use a hex key in the very top of the strut and a wrench for the bolt, but before you do that go to autozone and rent a spring compressor, because your gonna need it, any more questions hit me up, I've just finished my rears and still gotta do the fronts, your installing coilovers, or lowering springs? Gl with the install.
Old Aug 12, 2008 | 10:36 PM
Default Re: i need help on my stock struts !!! help please ! ((puma))
thnx on the comment, & i alreeady have the spring compressor. . . * im using coilover lowering springs w. the adjustable thing that goes in the center of the spring to lower it or raise it w. a tool . . . .but yeah can you give me more info, i do have hex keys, but what exactly do i do ?
Old Aug 12, 2008 | 10:37 PM
and where i put the hex key is on into the bolt at the top right ?
Old Aug 13, 2008 | 05:29 AM
any oneee ??!!
Old Aug 13, 2008 | 05:37 AM
Toe_Knee's Avatar
Default Re: (H0NDAdAddy LS)
Use the hex key to hold the bolt thing in place while you loosen the nut with a wrench or something. Be sure to use a spring compressor or the spring will fly in your face lol. Oh and I don't think you need the shield thing, it's just a dust cover isn't it?
Old Aug 13, 2008 | 05:46 AM
ok but the bolt is also where the hex key goes so i dont get it . but ill try todayy .
Old Aug 13, 2008 | 05:53 AM
Toe_Knee's Avatar
All the way at the top there is a slot for the hex key. Stick it in there and hold tightly. Below that theres the nut that holds the top cap. Use a wrench to loosen the nut while holding the hex key in place so the whole thing doesn't move.
Old Aug 13, 2008 | 06:03 AM
ok perfect ill try it today, thnx so much :D but what if i cant do it lol is there another way ?
Old Aug 13, 2008 | 08:28 AM
AlphaQup's Avatar
Your hex key looks like an "L" correct? Now stick the short leg of the hex key into the hex hole on the strut, lay the strut flat on a concrete surface with one foot on top of the strut/spring assembly. Now grab your wrench and start loosening that bolt as the hex key is being held back by the concrete floor. Comprende?
Old Aug 13, 2008 | 11:42 AM
(puma)'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0NDAdAddy LS &raquo;</TD></TR><TR><TD CLASS="quote">ok perfect ill try it today, thnx so much :D but what if i cant do it lol is there another way ?</TD></TR></TABLE>
Well you could put the struts on the car and have someone with an impact try to loosen them up,or take them somewhere and have a shop put them in an actual spring compressor. that's what I had to do for the rears, now the backs are gonna be a bit tough, the bolts under the car tend to seize, they're famous for that.
Old Aug 13, 2008 | 04:31 PM
thnx :] i did it ! lol i slammmeddd the front lol i had the spring compressor & everything i needed but i wasnt to confident that i could do it but i didd :D but now im qonnah move on to the back, but what do you mean they tend to seize ? are they harde then the front ones ?
Old Aug 13, 2008 | 04:32 PM
front. . . . SLAMMED :D qonnah raize it just a lil more when i get the rears in .
Old Aug 13, 2008 | 05:28 PM
(puma)'s Avatar
Very nice man, did you do everything yourself? And did the link I sent you help any? As far as the rear ones go its not that they're hard to do but the bolts under the car always seem to not want to come out so you really have to get an impact on them because a ratchet won't do it sometimes, almost like they're kinda welded on but they're not, so did the fronts go smooth, I may do mine this weekend, hit me if you need anymore help, also how's your ride is it stiff any? Lemme know how everything goes.
Old Aug 13, 2008 | 07:16 PM
thnx your a big help bud
Old Aug 13, 2008 | 07:22 PM
& ill be sure to take pics once its finished & team integra makes it look easier then it looks on the rear struts no ? lol
Old Aug 13, 2008 | 07:29 PM
ohh & yess the ride is good gotta watch out for those damn pot holes though
Old Aug 14, 2008 | 05:24 AM
(puma)'s Avatar
Niiice, man my ride is so damn stiff, sucks im savin to get some koni's next week, your on stock struts rite?
Old Aug 14, 2008 | 06:03 PM
Default Re: ((puma))
oh kool , good luck on your fronts & thanks
Old Aug 14, 2008 | 10:58 PM
jdmer329's Avatar
ill do it for you i got a strut compessor. and u need to get rid of those sheilds.
where u located
Old Aug 14, 2008 | 11:14 PM
JDM_CRX_PLEASE's Avatar
you dont HAVE to get rid of the sheilds..
you dont need a spring compressor either, i just shoot it into a trashcan.
Old Aug 14, 2008 | 11:17 PM
jdmer329's Avatar
if your putting sleeves on them you will my shileds didnt fit wen i put my ground control sleeves on. and shooting them in a trash can is weak. takes too sec's with a compressor
Old Aug 14, 2008 | 11:19 PM
jdmer329's Avatar
i see hes not doing sleeves. lowering spirings. if he bottoms out too much hell smash the sheilds. im not using sheilds. so id take them off jus to be safe.
Old Aug 15, 2008 | 12:52 AM
AcuraLsSE's Avatar
Also they say to cut the bump stops in half for that extra inch of clearance. At least my ground control instructions said to.
Old Aug 15, 2008 | 11:42 AM
yuep my old DC i cut the bump stops in half cuz you just crush them haha. my friend didnt do it and they were goneeeeee.
and shooting it into a trash can saves me the time to go to the dept. store and renting out sleeves. nothing wrong with shooting them somewhere. maybe in your face!
jk :]
upgrayedd
Mar 25, 2010 12:46 PM
97eksoldier
Suspension & Brakes
33
Oct 27, 2008 01:46 PM
spens 91 Ef
Oct 8, 2008 05:44 AM
Ziatic
Apr 4, 2004 02:17 PM
sCeRaXn
Jun 3, 2002 11:22 AM
