1991 crx si with surge when idleing
Old Aug 12, 2008 | 05:55 PM
almostjdmeg's Avatar
Default 1991 crx si with surge when idleing
I have a 1991 crx si with a b18a1 in it. It has a blox intake manifold with no charcoal canister on the car at all. Alright my issue is when the car it sitting at idle it constantly suges from 2000 to 500. I have already bled the coolant system and cleaned out the iacv valve. What should i do from here?
Old Aug 12, 2008 | 06:04 PM
esteen2's Avatar
Default Re: 1991 crx si with surge when idleing (almostjdmeg)
sounds like you have a vacuum leak.
Old Aug 13, 2008 | 07:26 AM
drummingpariah's Avatar
Check the ECU to see exactly what codes it's throwing. It's beneath the passenger's side kick panel (under the carpet where the passenger invariably kicks).
Old Aug 14, 2008 | 02:10 AM
doctorgonzo69's Avatar
Check all vacuum lines, then unbolt iacv and clean with carb cleaner, if still experiencing fluctuating idle, try, as inconvenient as this may be, swapping a known good ECU. Unplug and reinstall ECU fuse (or neg battery cable) after each of these actions.
Old Aug 14, 2008 | 07:13 AM
nickrex70's Avatar
i had this same problem with my crx... i have a b18 block with a b16 head and no one could help me either... first check your intake manifold gasket... if that is sealing properly.... check your how you ecu is communicating with your map sensor by checking the voltage
Old Aug 14, 2008 | 06:42 PM
Could it be a bad map sensor?
Old Aug 15, 2008 | 09:04 AM
nickrex70's Avatar
Default Re: (almostjdmeg)
a bad map sensor is a possiblity but highly unlikely... a way to check is to leave everything plugged in and use a multimeter to check the voltage at the ecu... for this youll need a pinout diagram and the recommended voltage... check it at the wires coming out of the ecu going to the map sensor... i think around idle is should be around 0.6v or so... how did the intake manifold gasket look?
Old Aug 15, 2008 | 10:06 AM
Default Re: (nickrex70)
THe intake manifold gasket is good. The reason i think it is the map sensor is because when i take the vacuum line off of the bottom of it it stops idling bad but somkes horribly
Old Aug 20, 2008 | 06:54 PM
nickrex70's Avatar
mine did the same thing... it could be bad but from my experience i would still say its a vaccum leak... take wd40 or some kind of spray similar and start spraying around the manifold... or hoses... when you find the leak it will fix the idle... then just repair as needed... dont go replacing parts unless you are positive it is bad... hondas are notorious for screwing with your head... mine does it to me all the time
Old Aug 20, 2008 | 07:11 PM
nickrex70's Avatar
oh and sorry but i just looked it up again and i gave you some wrong information... your map sensor should be reading some where closer to the 5 volt reference at idle
slowcrxsi
Mar 28, 2006 12:37 PM
starbury
Apr 18, 2005 10:53 PM
89CRXD16y7
21
Feb 7, 2005 07:49 PM
QWKPHKR
Jul 25, 2002 03:25 AM
mrc144
Jul 2, 2002 01:35 AM
