abnormal fuel pressure
just swapped my old motor back in after a complete rebuild. though rebuilt, i keep it stock with the exception of valve springs and retainers. i still have the walbro 190lph that is still being used from my old setups. the problem is that my fuel pressure is sitting at 64-68psi while at idle which is way high.
Things i've tried: changing fpr(one stock, one adjustable), changing fuel gauges.
car: 92 cx
motor: B16A
has anyone expierenced this before?
car: 92 cx
motor: B16A
cleared the return line, no dice.
i placed the return line in a bottom and primed the system, fuel came out as it should. also, when i unplug the return line, the hardline from the chassis spilled some fuel out so it seems to be clear from debris.
any other inputs?
any other inputs?
turbo Si
Mar 16, 2003 10:28 AM
