Help with Leakdown results
Old Aug 12, 2008 | 03:40 PM
guedo148's Avatar
Default Help with Leakdown results
ok, i've been burning oil and smoking because of my 3rd cylinder. i just finished replacing the valve seals and did a leakdown test to find out what was causing the problem.
i tested the 3rd cylinder at TDC and there was only a 4% leak, which is pretty normal. all other cylinders are less than 5% at TDC.
so then i rotate the crank so that cylinders 1 and 4 are are TDC (piston 3 is at the bottom of the cylinder) and the leakdown is at 20% here. i tested cylinder 2 with the crank in this position and it was only 5% leak.
so what would cause 15% more leaking air with the piston at the bottom of the chamber? is this my rings? or my cylinder walls? or what? i can't tell where the leak is happening.
it's obviously not a valve or valve guide because at TDC the leakdown is fine. also, keep in mind that the engine has been sitting for 2-3 months and hasn't been started.
what do you guys think?
Modified by guedo148 at 4:53 PM 8/12/2008
Old Aug 13, 2008 | 05:11 AM
guedo148's Avatar
anyone?
Old Aug 13, 2008 | 12:18 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: (guedo148)
ima say it.s ur cylinder wall on cyl3. .is this ur stock motor and/or has this motor always been in ur possesion??
Old Aug 13, 2008 | 12:58 PM
guedo148's Avatar
Default Re: (Egezzy)
no, it's a mildly built N/A b-series that i put in last summer. i rebuilt the bottom end with new bearings, rings, and rehoned cylinder walls. i don't know why the walls on cylinder 3 would be messed up since i got the block rehoned. damn, i don't want to take it all apart again.
Old Aug 13, 2008 | 12:59 PM
Egezzy's Avatar
have u had ne ovaheatin probs befo afta the rehone??
Old Aug 13, 2008 | 01:41 PM
guedo148's Avatar
it never overheated
just smoked some.. sometimes randomly, sometimes at high rpm. if i ran it hard then came to a stop, it would smoke when i started going again. i'd have to fill up the oil about a quart every 500 miles or so.
i had a b16 bottom end before i rebuilt the b18c1 and that was losing compression in cylinder 3 as well, so i thought it might be a valve or valve seal problem because i'm using the same head. but the valves seem fine.
Old Aug 14, 2008 | 09:26 AM
guedo148's Avatar
bump for help
Old Aug 14, 2008 | 09:50 AM
Egezzy's Avatar
i kno it was rehoned but was it mic.d aftawards to make sure errything was tru to spec??
i jus dont see how it could be nething besides the wall becuz of that readin.
Old Aug 14, 2008 | 10:16 AM
guedo148's Avatar
Default Re: (guedo148) (Egezzy)
it was rehoned by a reputable machine shop so i expect they made sure everything was good.
20% leak doesn't seem that bad, if i just use a thicker oil will that stop or slow down the oil consumption? is there annything else i can do besides taking everything apart again?
Old Aug 14, 2008 | 10:21 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (guedo148) (guedo148)
20% leakage is horrible.
Why are you worried about leakdown at BDC??? Depending on cams/angle/etc, your intake or exhaust valve may be starting to open/close
It could still be a valve guide and/or seal.
A worn hardly ever shows on a leakdown, unless its so bad that your valve never sits right
Old Aug 14, 2008 | 10:53 AM
guedo148's Avatar
Default Re: (guedo148) (Evs-One)
i'm worried about leakdown at BDC because at TDC it's only 4% - same with all the other cylinders. but at BDC all cylinders are less than 5% but #3 is at 20%
i thought at BDC the valves were closed just like at TDC?
Old Aug 14, 2008 | 11:09 AM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guedo148 &raquo;</TD></TR><TR><TD CLASS="quote">i'm worried about leakdown at BDC because at TDC it's only 4% - same with all the other cylinders. but at BDC all cylinders are less than 5% but #3 is at 20%
i thought at BDC the valves were closed just like at TDC?</TD></TR></TABLE> They are not.
Old Aug 14, 2008 | 11:14 AM
guedo148's Avatar
Default Re: (guedo148) (DonF)
hmm. then why was cylinder 2 only at 3% leak at BDC?
so maybe replacing the valve seals fixed the problem. if i only have 4% leak at TDC in cyl.3 do you think i'm good?
guess i'll assemble the head and start it up to find out.
Old Aug 14, 2008 | 12:11 PM
DonF's Avatar
Because the EX valves were closed on #2 and IN open on #3? Do some homework on home a 4 stroke motor works. It will help you later on. I do leak-downs at BDC. I have the cams out or the adjusters full lose.
Old Aug 14, 2008 | 12:16 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Because the EX valves were closed on #2 and IN open on #3? Do some homework on home a 4 stroke motor works. It will help you later on. I do leak-downs at BDC. I have the cams out or the adjusters full lose.</TD></TR></TABLE>
there's only so much one can do...
Old Aug 14, 2008 | 12:19 PM
guedo148's Avatar
i had the cams out while i did this test.
do you think i'm ok if i have good leakdown numbers at TDC in cylinder 3?
Old Aug 14, 2008 | 05:03 PM
DonF's Avatar
Then you have a taper , scores in the bottom of your sleeves. This is not rocket science, Something has a leak. Do your home work.Hard to see from here.
Let me ask you a question, are you happy with 20% leak at BDC? If yes you are good to go, If not figure out why.
Old Aug 14, 2008 | 05:12 PM
guedo148's Avatar
i'm not happy with it burning oil and smoking. guess i'll have to take it apart.
Stewie
Feb 1, 2006 06:31 AM
BROKE.eg
Oct 28, 2005 07:14 PM
SiRkid
Jan 4, 2005 06:34 PM
DOHC_EF
Jun 29, 2004 03:31 AM
