removing double stick tape
help. Whats the best way to remove d. Stick tape with out damaging the bumper paint? And where can i find it? The tape has been on for a while
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rufridn »</TD></TR><TR><TD CLASS="quote">3M adhesive remover</TD></TR></TABLE>
Where can i get that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OOOtony »</TD></TR><TR><TD CLASS="quote">
Where can i get that</TD></TR></TABLE>
x2
x2
Goof Off works just fine, but you can probably find the 3M stuff at a NAPA or other auto parts store. It would be a good idea to not let the goof off sit on the paint too long, by wiping it with a towel with water afterwards.
i got mine from Walmart. it's a spray can
Yeah, or you can try to saw it off with floss/ fishing line. Then go back with the spray to get off the residue. Might take a while if you just spray it and wait. Basically the same process you would use to debadge.
Good luck!
Good luck!
if the goo gone doesn't work for some reason, you can take some laquer thinner on a cloth and clean it with that. WARNING: the thinner can take off your paint if used too much.
if you want to take ANYTHING off your paint, you can can get an "eraser" from a paint/body shop. it's an attachment for a drill but that thing took off everything off my integra, including the adhesive from door guards and stickers that were probably as old as the car. =P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OOOtony »</TD></TR><TR><TD CLASS="quote">thx everyone got it off. Everything came off. Then i tried to take of the silicone took some paint off but it was on there for years. </TD></TR></TABLE>
so, what did you use to remove it?
that 3m removing thing it takes a while.. it takes off the tape then the sticky stuff are still there and you spray more and rub it off with a rag and it comes off clean
[Eg.6]LiLbOy916
Oct 28, 2006 09:23 AM
r2d97
42
Mar 11, 2006 01:34 PM
