harmonic balancer and flywheel question
Old Aug 12, 2008 | 12:52 PM
kadidle's Avatar
Default harmonic balancer and flywheel question
i have a new type s engine, and the crank pulley/ harmonic balancer was damaged to the point where my belts would get ruined, so i have my old one to put on. meanwhile i changed the clutch with the newer performance clutch i bought for my old motor and had the old motor's flywheel resurfaced so i put that on the new engine. i noticed that the crankshaft pulley and the flywheel both are balanced from the factory and differently than the new ones i received with the new engine. Are the flywheel and crank pulley both balanced with the crank of the motor it is going to be put on, or are they done like a car wheel and tire on a machine ?
Old Aug 12, 2008 | 03:51 PM
kadidle's Avatar
Default Re: harmonic balancer and flywheel question (kadidle)
bump
Old Aug 13, 2008 | 04:12 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kadidle &raquo;</TD></TR><TR><TD CLASS="quote"> Are the flywheel and crank pulley both balanced with the crank of the motor it is going to be put on, or are they done like a car wheel and tire on a machine ? </TD></TR></TABLE>
Very Good Question! Was wondering the same thing.
Old Aug 13, 2008 | 07:48 AM
kadidle's Avatar
Default Re: harmonic balancer and flywheel question (2point2)
bump
Old Aug 13, 2008 | 08:38 AM
Hawkze_2.3's Avatar
Well, Honda engines are internally balanced and you can bolt on any flywheel or crank pulley you want and if they are individually balanced it will be fine. So I would assume the engine itself is balanced separately from the external parts....
Old Aug 13, 2008 | 06:51 PM
kadidle's Avatar
Default Re: harmonic balancer and flywheel question (Hawkze_2.3)
bump
Old Aug 13, 2008 | 08:58 PM
Hawkze_2.3's Avatar
Hey no problem, anytime
Old Aug 13, 2008 | 09:06 PM
Acidcrakker's Avatar
I think hes talking about the aftermarket flywheels and pulleys being balanced.
Lets see you pull that hammer out on this post
Old Aug 13, 2008 | 09:27 PM
Hawkze_2.3's Avatar
Default Re: harmonic balancer and flywheel question (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">I think hes talking about the aftermarket flywheels and pulleys being balanced.
Lets see you pull that hammer out on this post</TD></TR></TABLE>
Yeah, the good quality ones are balanced...depends on what you get.
This post has no need for a hammer, there is no false information posted. But here's one just for you
Old Aug 14, 2008 | 04:03 AM
mattsnooz's Avatar
HAHAHAHAH,.... nice!, very nice!
One way or another, the hammer is comm'n out
Blaze45
Jan 6, 2012 09:17 AM
Hanmin
Apr 27, 2009 09:29 PM
h22aBB4
Dec 14, 2006 01:47 PM
Eclpze97
Jun 9, 2004 12:16 PM
hondaeg8
Jan 2, 2004 01:51 PM
