c5 crank question
Old Aug 12, 2008 | 12:42 PM
jrscb16eg6's Avatar
Default c5 crank question
spun a rod bearing in my c5.thinking of buying a eagle ls crank and rods for it. has anyone ever done this?i know what my advantages are im just wanting to talk to someone that has done this,and that has a little more info on it..
Old Aug 12, 2008 | 12:48 PM
Bradstard's Avatar
Default Re: c5 crank question (jrscb16eg6)
I had this happen before. I ended up doing a complete build. I ran an 89mm stroke and an 85mm bore. I ran with a stock LS crank and Carrillo rods. I never had a problem. I would have the crank checked before spending the money for the extra 2mm of stroke. If you do sell your ITR crank, they go for A LOT more than a used LS crank does. Also, if you plan on using cast pistons, keep the ITR crank. The counter weights are there for a reason. If you go with forged pistons, no need to have those additional counter weights on the ITR crank. Good luck.
Old Aug 12, 2008 | 01:01 PM
jrscb16eg6's Avatar
Default Re: c5 crank question (Bradstard)
thanks man if do go through with this im definatly going to have the rotating assembly balenced. the thought was just going through my head b/c i found a eagle 27lb crank and some brand rods(cant think of it off the top of my head) for like $800 new. so i was thinking that crank,aftermarket rods,and my type r pistons...it should be a little more peppy
Old Aug 12, 2008 | 01:21 PM
00-501itrspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrscb16eg6 &raquo;</TD></TR><TR><TD CLASS="quote">spun a rod bearing in my c5.thinking of buying a eagle ls crank and rods for it. has anyone ever done this?i know what my advantages are im just wanting to talk to someone that has done this,and that has a little more info on it.. </TD></TR></TABLE>
I currently have and Eagle crank in my 2.0 C5 turbo motor , no complaints , seems to be same as stock
EDIT :
Now that i read your second post , my opinion changes to , Maybe , you should get a set of CTR pistons , for less than 200 , youll feel more power from those pistons wayyyyy more than the crank and rods
Old Aug 12, 2008 | 03:02 PM
TODAwhore's Avatar
Default Re: c5 crank question (00-501itrspec)
more then likely your stock crank is junk if you spun the bearing good...not worth having it turned, its never the same as stock.
if you do get a eagle crank have it checked...i've seen some have out of round journals.
another option for the stock crank is this company http://www.marinecrankshaftinc.com/
good luck
blkteggy
Jan 18, 2008 01:43 PM
cherryhatch00
Jan 15, 2007 02:57 PM
Circuit Star-29
Feb 23, 2006 07:42 PM
NightHawkC5
Mar 4, 2003 06:56 AM
TheSwift1
May 29, 2002 10:42 AM
