my friend has turbo prob.
the check engine light is on and the ecu puts too much fule in the injectors so it wont idle right and it boggs out on take off this is a 92-95 civic greddy turbo kit but its on a 96 civic EX so the comp so diff.
if you're running turbo, you at least need an air/fuel controller and one session on the dyno, otherwise, you won;'t be running to full potential, get that stuff tuned, and if you can afford it...Engine Management
is he using the blue box?
check http://www.turbocivic.net
for more questions
My guess is he has the blue box hooked up wrong or not at all?
for more questions
